Results 1 to 10 of 16
Thread: easiest way to lower a ke70 wagon
    Scammer, DO NOT BUY FROM ME!
    Default easiest way to lower a ke70 wagon
    wats the easiest way the lower a ke70 wagon unshore cos thay have leaf springs
    Alex
    Wagga Wagga
    Fill the back with heaps of bricks. Also, bags of cement works too.
    Or you could get lowering blocks or have the leaves reset/flipped.
    r lowering blocks expensive
    Moderator Sam-Q's Avatar
    Endeavour Hills
    no, are you in vic I can make you some?
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    flipping the leaf springs would be the easiest way.
    FTP.
    Senior Member Dylan's Avatar
    Dylan
    lowering blocks shouldnt cost more than around 50 dollars
    Endeavour Hills
    I must not have been thinking straight yesterday, I have a Ke70 wagon in my front yard that I can use as a template, I could make up a big pile of them for whoever was interested.
    For the record, not ALL of the leafs can be flipped, the bottom one (which becomes the top) hits the leaf mounts. You could possibly grind this away though.
    You can however flip one or two leafs from your leaf pack. Or if you manage to find a longer sender pin that fits the hole, you can add a leaf.
    Depending on your use of the car, I would be aware of what blocks can do to your car. If its a daily car that may see a bit of rain every now and then, then by all means lowering blocks are a cheap an easy alternative. However if you intend on drifting it properly, blocks can cause lots of unwanted axle tramp.
    Resesting the leafs is also another option as mentioned.
    You could akways do what I did and find some hillbilly to make you some awesome low and stiff leafs from scratch. It will cost you though.
    As for the front, just read around the forum and lower the same way as any other KE/AE driver has lwered theres depending on your cars main use.
    What? The whole leaf pack in a KE can be flipped?
    When I did it, the bottom leaf (which becomes the top) would hit the front mount on the body of the car. So much so that it wouldnt go up high enough for the holes to line up.
    Senior Member bigdaddykane's Avatar
    Max
    Nsw
    Central coast
    maybe something was bent or out of shape ive seen ke70 ones all fliped before. lowering blocks are ok but i find it makes the rear end feel a bit shitty
  1. What is the cheapest/easiest way to get into rally.
    By anastasios in forum Dirt and Offroad
    Last Post: 28th April 2019, 09:56 PM
  2. Who's seling the lower lips for ke70's??
    By 85Trueno in forum Cars or Parts Wanted
    Last Post: 20th January 2011, 12:57 PM
  3. lower springs for ke70 vic
    By shaunpierre in forum Cars or Parts Wanted
    Last Post: 22nd July 2010, 05:31 PM
  4. best and easiest way to hook a horn up
    By bams_keto in forum Technical - Questions
    Last Post: 1st December 2009, 10:14 PM
  5. easiest AE86 Swap
    By A.Short in forum Technical - Questions
    Last Post: 31st March 2008, 05:06 AM
