Results 1 to 10 of 18
Thread: rb30 wont spark. need help it started the other day!!!!
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    Default rb30 wont spark. need help it started the other day!!!!
    I have an issue with my ke70rb30 i chucked some wiring on it and it started the other day now it wont get spark since ive wired it properly. the lights are on the ecu and there is power ot the coil. the injectors are firing??
    throw me some ideas it may be something i am overlooking
    AE86 THE BEST
    Senior Member DR86FT's Avatar
    Kaan
    Emerald
    Check power and sig to your coil if your getting injector pulse you should u have a sig for your coil or coils?
    Eddie
    sa
    how do i check sig to coil?
    AE86 THE BEST
    Kaan
    Emerald
    Test light or multimeter on volts setting. What head are u running
    Eddie
    sa
    all stock rb30, volts wile cranking?
    AE86 THE BEST
    Kaan
    Emerald
    To see if it's fluctuating while cranking at coil plug . Did u test injector pulse with a noid light
    Kaan
    Emerald
    Normally the plug on the dizzy are always a bit dodgy on the rb30
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    oath, you can actually buy a wire and plug kit now(oviously for a while) from repco/bursons/pep's etc for that plug as they do cause a lot of issues
    Eddie
    sa
    thats why it has been siliconed to fark haha havent touched the plug tho!
    AE86 THE BEST
    Veteran Skylar's Avatar
    Ken
    If injectors are going then it's not the CAS.
    Something/somewhere between the ECU and coil is broken.
    Put multimeter on frequency setting and probe the trigger wire to ignitor at the ignitor end. If you get a freq. on that while cranking, the wiring to the ignitor is good. If you get no pulse there then probe the same wire at ECU end. It's a borked ECU if you get no pulse there.
    Probe the trigger wire between coil and ignitor after that and look again for frequency. Ignitor is fine if you have freq. there.
    Have 12v at the coil?
    Is the ignitor earthed out?
  1. 4agze wont spark..
    By adds in forum Technical - Questions
    Last Post: 16th October 2012, 12:47 AM
  2. started motor
    By pen15 in forum Cars or Parts Wanted
    Last Post: 24th December 2010, 09:11 PM
  3. Cant get car started!
    By DAMO46 in forum Technical - Questions
    Last Post: 15th December 2009, 04:44 PM
  4. My build up (not started)
    By damo46 in forum AE86 Owners Forums
    Last Post: 13th August 2008, 04:15 AM
  5. I started a new job this week,
    By sprinterboy in forum Offtopic Discussions
    Last Post: 12th October 2005, 09:51 PM
