if you want 5 stud you will need s14/s15 hubs, curious why with ABS???
Hi All,
I'm after some knuckles from a S14 or S15 and the 5 stud hubs to match.
I will give preference to a set with the abs rings and location for sensor.
I don't need any of the brakes ect as I have R33 callipers that I will be using.
Cam
oops typo, will change OP now.
ABS is because the ecu im getting can run launch control so if later on i want to hook it up to the wheel speed sensors i have that option.
that would be fucking coool
best of luck ill ask a mate of mine, he is doing 5 stud on his s13, see if he has any left overs
