looking sweet,arent sigmas hugeeee thow?
Flat out with work!
Got some sigma arms on the way.
Will post up pic's when I get them in.
Three are 2 different types, bolt in ball joint and press in type. Bolt in are very long, press in are the more common ones used, not quite as long.
I have adjustable camber tops so I can dial out excessive camber.
Here read this
check out what slydar has to say, and page 3 for some pic's of his cars with sigma
Been a while, havent lost interest.
Windates as follows,
I have a quad light grille, surrounds, lights and bracket set on the way from Malyasia.
Also, I have been given an SC14 of a 1GGZE as well sourced a butt load of SC12/14 spares for it.
I need to find an SC12 to GZE bottom mount - If you got one PM me
Plan is SQ engineering GTIR plenium adaptor
GTIR plenium - try to use the stock GTIR blow of valve if it will fit (may have found already)
GZE or similar intercooler front mounted - Water sprayer due to the huge amount of heat produced by the SC14.
Set of 1J/2J or 3SGTE injectors
I have no idea what sort of power this will churn out, but I can wait to piece it all together!
More updates to come!
Good stuff, keep the updates coming... will love to see this thing finished.
Wouldn't the 10.5:1 compression ratio be bit high for forced induction on pump fuel?
What ratio are GZE's?
It'd be cool though. Love the equips.
let me know wen u get ur quad light setup, ive been waiting over 2 months already, not far off gretting on a plane and going on a culling spree
happy to you join your party
The more the merrier
I've seen some prime examples stock ST20V with turbo's running low boost without any issues?
Check this out.
267rwhp @ 7200rpm, 10.5 compression ratio, stock silvertop internals 15psi.
Yes, 10.5:1 is a little on the high side, however as long as I get a good tune, run it good fuel, and don't go stupid on the boost 8-10psi max, I believe it will work fine..
Did you guys buy from ebay, or facebook?
I got mine through ebay.
I don't rely care how long it takes, as long as I get the parts.
I used paypal, so if it don't show I take it up with them and get my money back.
