FRICTION STABILITY
Consistent braking...from first stop till last
LOW FADE
When the heat’s on, STREET ROAD TRACK keeps delivering
HIGH FRICTION
Performance brakes that respond to your driving style
Bendix Street Road Track brake pads are designed to suit sports and performance car enthusiasts for high speed driving applications. They have been developed by one of the world’s leading high performance friction material manufacturers incorporating the latest technology and extensively tested under extreme conditions. The rear of the pad also features a gasket, for reduced noise and increased heat resistance.
Street Road Track adjusts to your driving style, so you don’t have to adjust to the style of your brakes. They deliver consistently brilliant braking, with high tolerance, low fade, long wear and high friction in all sorts of conditions:
• The confidence to handle busy, unpredictable driving on the STREET where conditions can change in an instant.
• The reliability to negotiate mountains with your foot consistently on the brake or cruising the open ROAD with long intervals between braking.
• Or lap after lap of hot, hard, last second braking at the TRACK.
DEVELOPED FOR SERIOUS PERFORMANCE CARS AND DRIVERS
Bendix Street Road Track brake pads have been developed and comprehensively tested by leading friction engineers to create a pad designed to handle a variety of applications – street, road and track. We’ve rigorously assessed them against other leading brands under the most torturous conditions so Bendix Street Road Track deliver superior control and consistent braking from the first stop to the last.
Have confidence to work ‘em hot and hard, knowing they’ll keep on delivering.
Bendix promotes responsible, lawful driving of motor vehicles with full compliance with all applicable road laws and Bendix does not promote or support street racing. Brake performance may be adversely affected by road and weather conditions and vehicle characteristics.
Bendix Street Road Track is a high performance friction material. It has been developed and manufactured to give superior brake performance under all conditions.The material formulations used on typical OE and general purpose aftermarket brake pads are biased toward comfort ahead of performance; Street Road Track takes the opposite approach.With a high friction coefficient and low compressibility, Street Road Track is more likely to produce brake noise than lower performance friction materials.
Every effort has been made to minimise brake noise without compromising performance. Street Road Track is manufactured with composite damping gaskets and OE pad geometry, greatly reducing the chance of noise. However, some noise will be present on sensitive vehicles.
Bendix is Australia’s largest manufacturer of automotive friction materials and the only Australian company supplying friction materials for use on new cars made by Australia’s car makers. Based in Ballarat, Victoria, Bendix employs over 750 staff and utilises the latest friction manufacturing technology to make the highest quality brake friction products available in Australia today.
For more information on Bendix including the full range of Bendix brake pads
and Put your foot down with confidence.
