been busy,drive soon
updated specs list *
motor:
jap 16v bigport
full rebuild-
ported head
milled
back cut valves
king mains
king big ends
lightened harmonic ballance pulley
slight mill on block
diamond hone on bores
recoed oil pump
new alloy rad
standard jap headers into custom secondaries
t50 with ajps shifter rebuild kit
lightened fly wheel
exedy heavy duty clutch
braided clutch line with speed flow fittings
jap loom
jap ecu
custom intank fuel system with walbro 255lph pump
ae71 gbox crossmember
86 engine crossmember
Diff:
jap t series
disc brake
braided lines
trd 2way
trd 4:77 final drive ratios
ebc red stuff pads
all bushes nolathane in rear end
suspension:
front-
t3 86 sleeve kit
t3 86 camber tops
t3 needle roller bearing spring hats
6kg springs
trd blue 5way adjustable shocks
adm 86 disks and calipers with high temp metal pads
strut brace
ajps lock spacer
86 arms
xt130 lcas with nolathane bush kit and fresh ball joints
ajps 40mm rcas
new trw tie rod ends
super pro nolathane caster rod bush kit
rear:
ajps adjustable spring perches
lovells 4.5kg springs
pedders sports ryder shocks
strut brace
interior:
new bride fixed back copy (drivers)
stripped sound deadner
twin cam steering wheel
pioneer stereo
trd gear knob
exterior:
wheels- front:ssr mklll 14x8 -0 with 185/60 bridgestone re001
mad house lip
c xxx grill badge
finshed doing my intank pump system seems to be working well and is neat
also got a new diff
t series
trd 4:7s
trd 2way
disc brake
braided lines
ebc red stuff pads
also rebushed all the trailing arms with nolathane
also got an ae71 gbox crossmember put that in because 86 one sat low was shit
and i got quad lights sitting here now too
thats it for now
next on the cards is ecu leaning towards black box m1, hks or supertech valve springs and cams looking to go kelford 288s at 8.5mm lift cbf to spend the money on todas for this motor plus kelford make a great cam
wet skid pan day this sat at ec should be heading out
pics soon been lazy
yeee
go haltec
haltec very basic ecu
the dyno pull to 300rwkw
smoke show sly tod
