Results 1 to 10 of 11
Thread: Convert T50 H pattern to sequential
    Russ
    Congupna
    Default Convert T50 H pattern to sequential
    Guys,
    anyone know anyone who does these??
    This mob were claiming they were going to, but that was years ago...
    Any clues, hints most appreciated..
    Dec 2010
    Kevin
    ZH
    Rotterdam
    The Netherlands
    I've heard of this device: ikeya formula sequential shifter
    But don't think they have it for a T50 but it might work with some customizing.
    If it's good for your box is a different story though...
    ADM AE86 Levin
    Russ
    Congupna
    Thanks for the reply - aware of gearbox limitations, but more looking to avoid mis-shifts than "slam" through gears as you would in a true sequential.
    Had seen that one....
    Also these:
    Anyone else got a lead??
    I read an old thread that claimed an AE86 with sequential, but cannot find now, but not sure if true sequential or converted "H" pattern.
    Senior Member Dylan's Avatar
    Dylan
    Thought of just rebuilding the standard shifter with a kit through AJPS. Its amazing the amount of slop that gets reduced.
    Not really a fan of short shifters as they alter internal leverages in the trans, and will damage the synchros in time.
    Veteran takai's Avatar
    Jul 2009
    Vic
    Melbourne - Northish
    Pray tell how changing the pivot point on the shifter alters the internal pivot points in the gearbox?
    Also pray tell how a short shifter by default damages the synchros of the gearbox.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I am with Takai, did you get that crap off Donnon? with a short shifter you actually have less leverage available to damage your internals of the gearbox due to the mechanical disadvantage
    Senior Member kaibeecee's Avatar
    Pete
    I think peoples basis for short shifters ruining boxes are from drifting. fast, abusive shifts.
    But drifting and shifting harshly regardless of the length of internal throw will ruin a box.
    and any sequential box will require a straight cut gearset.
    Your best bet would be to find a 2nd hand hollinger and adapt the bellhousing.
    Russ
    Congupna
    Pete,
    actually the best option is to get a Quiafe sequential and then adapt a bellhousing. work out about $5K cheaper
    BTW have used short shifter and LOVE it - whole lot better than remote shifters too.
    Wanted to keep the T50....
    I guess it's too hard/expensive..
    Moderator Frak's Avatar
    Jamie
    He is correct, the speed of the shifter below the pivot point is increased, if synchros are on the edge, a short/quick shift will fuck em. draw it up and look at the distance the selector is moving through with respects to the movement of the gear lever above the pivot point.
    Hachiroku since 1994
    Veteran shift_rook's Avatar
    SE Burbs
    the conversion would be really expensive and most likely not really worth it in the end, if you're missing shifts with a fresh h pattern shifter you're doing it wrong
  1. EMS stinger - sequential ignition
    By Gabe in forum Technical - Questions
    Last Post: 2nd September 2011, 05:55 PM
  2. Sequential shift for w5x?
    By DR86FT in forum Technical - Questions
    Last Post: 14th September 2010, 10:13 AM
  3. what do i need to convert
    By rlnbye in forum General Topics (No Technical Questions)
    Last Post: 30th June 2008, 01:40 AM
  4. MicroTech MT8 sequential fire with hand controller
    By Ludachris in forum Car Parts For Sale
    Last Post: 16th May 2008, 12:38 PM
  5. Rebuild or Convert?
    By Will(SPA50) in forum Technical - Questions
    Last Post: 25th January 2008, 05:14 PM
