post edited
2JZ MX83 CRESSIDA for sale
Specs are:
2JZGTE - about 95 000ks
R154
NPC 500hp clutch - still wearing in
ebay staino manifold, no cracks or repairs
PROBOOST T66 turbo (.70 A/R front, 1.00 A/R Rear housing
TURBOSMART 48mm progate
850cc injectors
Sard rising rate fuel regulator with Turbosmart mechanical gauge
Greddy cam gears
Microtech LT12s
Microtech X6
Microtech digi dash
600 x 300 cooler with 3" stainless pipework
Walbro 255lph intank lift pump
Redline 1L surge tank mounted in boot
Bosch 044 fuel pump feeding engine
Ross 1500hp rated Metaljacket harmonic balancer
JZX81 Chaser Strut Brace
R33 GTSt 4 pot calipers with BA falcon rotors
Double rear swaybar setup
3" exhaust with new stainless Lukey muffler cannon removed
Locked diff, i have lsd diff to go in which has the upgraded spring, re-arranged clutch's and was told by the diff guy it is in very good condition
Bag of bushes for front and rear
Since ive had it i re-wired the microtech to get rid of the birds nest
re-built the alternator
fix the fan belt arrangement to stop it squealing
bought the digi dash, muffler, bushes, lsd diff
Makes 415hp on 17psi with no timing and cam gears set to 0
Located in Mt mee QLD
10K
THE EVOROLLA none of this SR shit . . . EVO 7 powered bitches
https://www.facebook.com/KeConversions
KE conversions - making your conversion simple
4AGE CA18 SR20 BEAMS 1UZ to KEXX mounting kits and hydraulic pedal box's available
post edited
post edited
to the top
Hey bud can u pm ur number and is it auto or manaul
It Aint A Motor If It Aint A Rotor.!!!!!!!!!!!!!!!!!!
Sorry bro didn't see the r154 part cheers
still for sale?? i may be interested
electrics work? ie door locks, windows and stuff
digi dash, for the microtech? or a jzx81 digital dash??
anything to do for road worthy?
still have it although it may be spoken for. all electrics work, standard dash but digi dash is all you need. back tyres have camber wear and brake hoses need replacing. As for a roadworthy it depends how strict your guy is
FUKN tuf.
will contact you pending a couple things!
and those things are???
