Results 1 to 10 of 14
Thread: I finally got an '86!
    Member GrumpyRacing's Avatar
    Dec 2009
    Cliff
    Laverton
    Default I finally got an '86!
    Well after being on this forum for a while and having a long obsession with the ae86, i finally managed to buy myself one!
    So i got this one off here in sa. Has the 4age conversion done using an ae82 loom.
    Its a pretty solid car but the body is definatly in need of some love has dints and bad touch ups on it. Dint on one rear arch. And a small amount of rust in the b pillar lower area.
    Basically i am happy with the car but i am going to have to clean up the body a fair bit. Im also going to do a clean up of the wiring set up cos its pretty messy. Also need some trims for the rear that are missing
    Anyway specs are below and some photos
    1985 ADM AE86
    Engine
    JDM 4age running an AE82 loom and JDM ecu
    JDM gearbox extreme clutch
    MSD ignition blaster 2
    New Radiator
    Jasma extractors and 2 ¼ exhaust into 2 mufflers
    running a JDM fuel tank
    Suspension
    Front
    Cusco Camber tops
    AJPS coilovers with Excel G inserts 8kg springs
    AJPS 40mm RCA's
    XT130 LCA's
    Powersteering arms
    new rack ends plus lock spacer
    Rear
    Excel G shock absorbers
    6kg springs good height
    17mmish after market rear swaybar
    Noltec panhard rod
    Superpro trailing arm bushes
    standard S-series diff
    Interior
    luisi steerer
    dash mat
    Wheels
    14x7 longchamps fronts
    14x8 longchamps rears
ID:	21700   Click image for larger version.
ID:	21701   Click image for larger version.
ID:	21702   Click image for larger version.
ID:	21703   Click image for larger version.
    Steve
    Cairns
    Nice one. It looks pretty good and most of the hard work has already been done.
    Member k.aaron's Avatar
    Aaron
    Preston
    Nice one!
    I'd rather have an '86 than a girlfriend.
    Veteran Robo86's Avatar
    Rob
    cool man, nice one
    http://shirtstuckedin.com/
    my corolla
    Bosman Wholesale Tyres
    3274 5374 - Roy
    Dec 2009
    Cliff
    Laverton
    Yeah all the suspension work, plus the engine conversion is done so it ment i didn't have to do it. Lol.
    Its pretty much the setup i would go with anyway.
    Just means the money i would spend there can go into the body and interior. Already got some nice recliner race seats to go into it.
    Dec 2009
    Cliff
    Laverton
    Well my nice new '86 is about to get some big love!
    It has some issues at the moment and they are
    A smokey engine
    Gearbox that won't select 3rd on down shift unless you go 4th over to second then back up to 3rd
    Very very noisey diff that sounds like a supercharger wine lol.
    Warped rotors and warn brake pads
    And a simple one that the steering wheel is to big!
    Solution!!!!!
    Nice fresh rebuild of a bigport 4age
    Grab spare t50 and put it into car
    Take fresh built 4age and install it to the car
    Install spare s series diff into car
    Install nice new shiney rotors and new high temp pads to car.
    Install fully sick drifting deep dish steering wheel lol.
    And then we are done!
    I believe i am gonna be busy this weekend!
ID:	21968   Click image for larger version.
    Steve
    Cairns
    Busy weekend, but will be like a new car afterwards though. Go go go!
    Dec 2009
    Cliff
    Laverton
    Its interesting trying to build the engine and also pull one out at the same time! Lol
    Head is assembled ready to bolt to block about to do pistons and rings plus crack and bearings too.
    Engine has only the gearbox bolts holding it in an is ready to come out after the lunch break to see my girlfriend and thank her for letting me be in the car hole all weekend. Lol.
    Any got some nice brake parts here!
    Look at the brand of the rotors!!! Oooooo pretty. Lol
    Dec 2009
    Cliff
    Laverton
    Ok another update while i take a little rest from bending over an engine.
    Then bottom end is almost complete. Just missing water pump and thats about it. Here is a tip for people when ordering rod bearings for a 4age make sure you know which rod journal size you have. There is a 40mm and 42mm. Because when you go to put you nice new king bearigs into your rods and discover you have 42mm bearings but you wanted 40mm one it really pisses you off!!!! #*#*#*#!!
    lucky i have a few spares laying around and another set of nice bearings presented themselves.
    Anyway the cylinder head is also part assembled. New stem seals all valves back in with springs and buckets installed. Clearances checked with it off the block cos its so much quicker and easier.
    So after my food brake it will be time to assemble a head to a block!
    Oh also the race seat is now mounted with the new wheel plus the race harness is half in. Just waiting for a delivery from AJPS for my harness bar (Thanks david).
    Some pictures
ID:	21987   Click image for larger version.
ID:	21988   Click image for larger version.
ID:	21989   Click image for larger version.
    Dec 2009
    Cliff
    Laverton
    And here are some pictures of how the engine looked before i got to it
ID:	21991   Click image for larger version.
ID:	21992   Click image for larger version.
ID:	21993   Click image for larger version.
  1. Finally an Old vs New 86 Video
    Last Post: 25th August 2012, 04:52 PM
  2. Finally got my first Sprinter !
    By Minivanman in forum AE86 Owners Forums
    Last Post: 29th April 2012, 08:56 PM
  3. ae86 finally
    By mcBen in forum AE86 Owners Forums
    Last Post: 3rd April 2012, 07:31 PM
  4. When it all finally comes to an end..
    By Matt-AE86 in forum Offtopic Discussions
    Last Post: 4th February 2010, 09:37 PM
  5. Finally ^_^
    By eastcoastdrifter in forum Offtopic Discussions
    Last Post: 7th February 2007, 05:41 PM
