Results 1 to 10 of 13
Thread: t50 question boys
    User fantapants's Avatar
    Pat
    Default t50 question boys
    hey guys
    chasing a simple measurement i havnt been able to find online
    does anyone know how far recessed the input shaft is from the face of a t50 4age bell housing?
    06/07/2011
    Veteran timbo's Avatar
    Tim?
    Wild West
    Does it need to be exact? You could probably work it out via a full clutch setup, the shaft would have to sit at least half way through the clutch plate.
    Pat
    i dont have a gearbox, only a bell and a engine pulled apart. i have attempted to make the numbers up using maths, just looking for confirmation
    06/07/2011
  • #4
    Glenn ke_70's Avatar
    Clay
    Barossa!
    i'll cruise down to my bros after work tomorrow and measure for you.
    you looking at tape measure spec or micrometer spec?
  • #5
    Tim?
    Wild West
    Ah righto, I'd measure the box lying around but I have no spare bell housing...
  • #6
    Pat
    tape measure spec is perfectly lovely clay
    thanks timbo, appreciate the attempted help anyways
    06/07/2011
  • #7
    Peter
    Pat
    With a tape measure, the distance from the face of 3a bell housing to the input shaft on a T50 is 5mm.
  • #8
    Clay
    Barossa!
    5.5mm actually
    and its 28.5mm to the start of the spline too
  • #9
    Moderator Sam-Q's Avatar
    Endeavour Hills
    well I have 4.3mm from the face of the bell to the end of the shaft and 6.6 to the start of the spline
  • #10
    Clay
    Barossa!
    2.3mm for spigot bearing?
  • Page 1 of 2 1 2 LastLast
    1. T50 gearbox filling question
      By ke_70_blue in forum Technical - Questions
      Last Post: 4th December 2012, 08:42 AM
    2. jdm t50 question
      By pen15 in forum Technical - Questions
      Last Post: 27th March 2009, 10:56 AM
    3. hilux diff t50 and na bigport ANOTHER QUESTION ADDED
      By 350hp4agte in forum Technical - Questions
      Last Post: 13th December 2007, 05:44 PM
    4. T50 Question
      By RyGuy86 in forum Technical - Questions
      Last Post: 29th September 2007, 11:14 PM
