Results 121 to 121 of 121
Thread: EOI - CNC AE86 Hubs in standard size and +10mm track
Threaded View
    Veteran slide86's Avatar
    Huw
    Hills
    Default EOI - CNC AE86 Hubs in standard size and +10mm track
    Hi,
    I have the opportunity to have some AE86 hubs CNC Machined from scratch at a good price.
    I am currently having a pair made for myself and wanting to know if there is enough interest to have more produced.
    There will be two types available, a standard copy of a factory hub OR one that will give 10mm track per side! This means you will have 20mm extra track total before and control arm, spacers or wheels fitted.
    Be aware, you cannot take this 10mm off if you want, its part of the hub.
    All hubs will suit standard AE86 wheel bearing kits, and I am able to supply new wheel bearing kits with hubs.
    These Hubs are made LOCALLY in SOUTH AUSTRALIA, by a large CNC company that make other CNC Motorsport items and supply items to companys such as MAD DAT.
    The price for two (2) hubs (standard or +10mm) with no studs or bearings will be approx $300 DELIVERED to your door. (Including postage)
    Wheel bearing kits will be $30 for both sides (If required)
    Sourcing studs can be left to you depending on length you wish.
    A deposit of 30% will be required before they will be produced, and production time will take 3 weeks.
    Please post interest here. If we get 10 or more people i will DEFINITELY give the go ahead......any less and we might do a one of run of them.
    (I have Nicks permission for this thread)
    Regards
    Huw
    Interest
    1. Mclevin DEPOSIT TAKEN
    2. y b nrvs
    3. ae86 drifter DEPOSIT TAKEN
    4. Maciek
    5. Slide86
    6. AJPS
    7. that guy 93 DEPOSIT TAKEN
    8. Kowan DEPOSIT TAKEN
    9. Billet86 DEPOSIT TAKEN
    10. Sikazmods DEPOSIT TAKEN
    Recapping these are CNC milled OEM replacement AE86 hubs, they DO NOT include studs or bearings, but these items can be supplied.
    DEPOSITS WILL BE REQUIRED BEFORE PRODUCTION STARTS.
  1. Replies: 2
    Last Post: 2nd May 2011, 08:48 PM
  2. wanted standard front struts and hubs for corolla
    By porter in forum Cars or Parts Wanted
    Last Post: 2nd April 2011, 08:17 AM
  3. standard ADM front swaybar size.
    By maxhag in forum Technical - Questions
    Last Post: 8th September 2010, 02:22 AM
  4. Need standard ke front struts, lcas, hubs
    By Brenton 86 in forum Brisbane & QLD Events and Discussion
    Last Post: 21st July 2009, 02:50 PM
