Page 1 of 13 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 1 to 10 of 121
Thread: EOI - CNC AE86 Hubs in standard size and +10mm track
    Veteran slide86's Avatar
    Huw
    Hills
    Default EOI - CNC AE86 Hubs in standard size and +10mm track
    Hi,
    I have the opportunity to have some AE86 hubs CNC Machined from scratch at a good price.
    I am currently having a pair made for myself and wanting to know if there is enough interest to have more produced.
    There will be two types available, a standard copy of a factory hub OR one that will give 10mm track per side! This means you will have 20mm extra track total before and control arm, spacers or wheels fitted.
    Be aware, you cannot take this 10mm off if you want, its part of the hub.
    All hubs will suit standard AE86 wheel bearing kits, and I am able to supply new wheel bearing kits with hubs.
    These Hubs are made LOCALLY in SOUTH AUSTRALIA, by a large CNC company that make other CNC Motorsport items and supply items to companys such as MAD DAT.
    The price for two (2) hubs (standard or +10mm) with no studs or bearings will be approx $300 DELIVERED to your door. (Including postage)
    Wheel bearing kits will be $30 for both sides (If required)
    Sourcing studs can be left to you depending on length you wish.
    A deposit of 30% will be required before they will be produced, and production time will take 3 weeks.
    Please post interest here. If we get 10 or more people i will DEFINITELY give the go ahead......any less and we might do a one of run of them.
    (I have Nicks permission for this thread)
    Regards
    Huw
    Interest
    1. Mclevin DEPOSIT TAKEN
    2. y b nrvs
    3. ae86 drifter DEPOSIT TAKEN
    4. Maciek
    5. Slide86
    6. AJPS
    7. that guy 93 DEPOSIT TAKEN
    8. Kowan DEPOSIT TAKEN
    9. Billet86 DEPOSIT TAKEN
    10. Sikazmods DEPOSIT TAKEN
    Recapping these are CNC milled OEM replacement AE86 hubs, they DO NOT include studs or bearings, but these items can be supplied.
    DEPOSITS WILL BE REQUIRED BEFORE PRODUCTION STARTS.
    Gone
    Joel
    Picton
    What material these made from?
    Glenn ke_70's Avatar
    Clay
    Barossa!
    possabily keen pending time and material.
  • #4
    Moderator Frak's Avatar
    Jamie
    Many moons ago I thought about machining up some alloy hubs, after talking to a V8 supercar fabricator I decided against it, he shed some interesting light on the cons of alloy hubs on the road.
    Hachiroku since 1994
  • #5
    West
    lol @ zero actual info to back up negative comment.
    I noticed Group 4 fabrication does this also, out of the UK, but about 180 pounds per hub in alloy.
    Plus freight.
  • #6
    Veteran slydar's Avatar
    Dimitri
    Quote Originally Posted by Frak View Post
    elaborate.
    78's
  • #7
    Anthony
    If youre replacing them every couple of hundred hours theyre probably great.
  • #8
    Gone
    Joel
    Picton
    Y would you replace them every hundred hours?
    If you use a hi grade alloy it will be fine.
    Aircraft wings and hi load components are made oh hi temper alloys and tested to over 120,000 hrs without fault .
    So saying they need to be replaced every couple hundred hours would not be true.
    Also these alloys experience and carry much higher loads then a 1000kg car.
  • #9
    Anthony
    I don't know, perhaps the same reason F1 teams who can afford alloy wheel nuts replace them every 2 races and the teams on a budget run steel wheel nuts. Aluminium is awesome at jobs like aeroplane wings. I just think undercarriages are a little different. Thought I saw a fair bit of steel last time I looked at a planes undercarriage too.
    My comment related to the fact that I am sure V8SC teams replace theirs every couple of hundred hours. When you want a road car to do 10s of thousands of hours in a public space, it's a complete different proposition.
  • #10
    Gone
    Joel
    Picton
    Landing gear is a different kettle of fish, it needs to withstand forces across many axis, your run of the mill 737 has a MTOW of just over 85 ton and a MLW of 71 ton, then take in G forces ..
    I thing your wheel nut eg may be a thread re torque issue rather then a structural failure of some sort?
    I'd run alloy hubs if they were made from a hi tempered alloy
  • Page 1 of 13 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
    1. Replies: 2
      Last Post: 2nd May 2011, 08:48 PM
    2. wanted standard front struts and hubs for corolla
      By porter in forum Cars or Parts Wanted
      Last Post: 2nd April 2011, 08:17 AM
    3. standard ADM front swaybar size.
      By maxhag in forum Technical - Questions
      Last Post: 8th September 2010, 02:22 AM
    4. Need standard ke front struts, lcas, hubs
      By Brenton 86 in forum Brisbane & QLD Events and Discussion
      Last Post: 21st July 2009, 02:50 PM
