what i have done on my 16v quad conversion is,
Using an electric air pump.
There is a map sensor in the booster in which is run off a jaycar adjustable relay box.
When the map reading gets below a set Voltage aka, pressure,
the pump zaps on for a second and provides the lost vaccum.
Been running it for 2-3 months now with no problems,
it has a normal feel in the pedal and its an easy way to get a strong MAP signal while having good brakes.
hope it helps
