Results 1 to 5 of 5
Thread: 4age into ae86... Help help
    Junior Member Hella86's Avatar
    Apr 2011
    Joel
    Default 4age into ae86... Help help
    Hi guys.. I have pulled a 4age 16v blue top out of a ae82 and dropped it into my ae86... Everything is now finished but when I start the car it turns off.. The only way to keep it running is to hold your hand on the key... To me this means I have missed a Ignition#wire.. So now I am trying to find a wiring diagram??? Any help.. Does it sound like i am on the right path?
    Veteran Nikkojoe's Avatar
    Tom
    Sounds like your car runs out of fuel. Its either injectors dont have power or the circuit opening relay aint working correctly (assuming you have wired it with one).
    Im more pointing to the latter. You probably have the start signal hooked up to the relay so that when it cranks the fuel pump works, but you have an issue with pin FC (green/red wire) not being earthed when car is running. You either need to connect that wire up to the ecu OR check that the ecu is working correctly. Pin FC on the ecu has been known to fail on some occasions, and you may need another ecu.
    A temporary fix would be to earth the pin on the relay, but only for the short term (pump will work as soon as ignition is on).
    Apr 2011
    Joel
    I have for wires left on the ECU.. G/R,B/W,V/W,R are the left over wires.. So by what your saying if I earth out FC (G/R) that should fix my problem?
    Join up the 2 G/R wires... G/r from the ecu provides earth to G/R from the FOC.
    Blue/Black from the FOC run it to your fuel pump
    Tom
    No, pin fc earths to latch the FCO (fuel circuit opening) relay. I am not sure if you are running this relay.
    The better question would be how you wired up your fuel pump....
    Check here for more info
  1. Replies: 2
    Last Post: 2nd September 2012, 08:44 PM
  2. 4age,4Age Parts, Ae86 Parts, Drilled Slotted Rotors
    By the_van_can in forum Car Parts For Sale
    Last Post: 14th October 2011, 10:10 PM
  3. Replies: 6
    Last Post: 23rd March 2009, 06:02 PM
  4. [AE86] Willy's 4AGE aus-spec AE86
    By slide86 in forum AE86 Owners Forums
    Last Post: 19th December 2005, 05:57 PM
