Results 1 to 3 of 3
Thread: Blacktop 20v 4age standard cam specs
    Timmy D
    North
    Default Blacktop 20v 4age standard cam specs
    Hey guys I'm after the standard cam specs for the blacktop 20v 4age.
    Need to know the timing of start of the lift
    And the duration
    Inlet and outlet
    JJ
    Gone
    Joel
    Picton
    gee google maybe?
    http://www.billzilla.org/4agstock.htm
    inlet cam is 250degrees, 8.4mm of lift
    exhaust came is 250 degrees, 7.6mm of lift
    Timmy D
    North
    Thanks!
    Since your so amazing at using google can you please find me the same specs for 3sge blacktop beams?
    JJ
  • Similar Threads
    1. Replies: 2
      Last Post: 21st July 2012, 02:00 PM
    2. 3sge beams blacktop stock cam specs
      By Tim.duncan in forum Technical - Questions
      Last Post: 4th October 2011, 08:55 PM
    3. CROWER 4AGE Forced induction cam specs
      By kerola in forum Technical - Questions
      Last Post: 15th September 2010, 10:51 AM
    4. Comp on a Standard Blacktop 20v
      By wideslider in forum Technical - Questions
      Last Post: 24th April 2008, 12:30 AM
    5. Blacktop 20v front cam gear cover...
      By shelldrake in forum Cars or Parts Wanted
      Last Post: 27th August 2007, 09:32 PM
