Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: ecu's
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    Default ecu's
    hi guys, im looking into buying a new ecu as my adaptrnic has fried on me 3 tmes now and im over it
    what do you guys recommend???
    im thinking possibly a motec M4
    i dont want a new ecu but if the adaptronics keep doing this i cant aford to keep using them
    discuss pros/cons
    MY JZX83 (clicky)
    Senior Member amulday's Avatar
    Amulday
    Central
    A cheaper alternative to the Motec is the Autronics. A few mates had them in their evo III's with good results, both the motec and autronic are probably overkill when there are guys getting the numbers and reliability with wolf 3d/haltechs ect...
    I personally had a Wolf 3d V4 with handcontroller for the VR4 and many other guys ran them without a hitch. The only issue now is that Wolf have moved onto the V500 and aren't really supporting the V4 anymore.
    amulday.sam
    HR ARMY
    RED BEAR
    Ryan
    qld
    brisbane
    Aust.
    rewire the adaptronic?
    by changing ECU's, just because its shorting out is pretty wack logic, especially one that is otherwise running your motor fine?
    Senior Member n00bvak's Avatar
    Novak
    SOR
    heard many good things of the EMS stinger ecu. I am actually gettin one installed on my car soon-soon.
    http://www.enginemanagementsystem.com/frameindex.htm
    Motec would be way overkill for most people, unless you are into tunning every minute thing and paying through the nose for it.
    Id stay away from wolf3d, tunners nightmare apparently, many places refuse to tune over here in perth.
    Also if your frying ECU's, maybe there is a wiring/fuse issue in your car rather than the ECU being a problem, prolly a good idea to get that checked out before you fry another one.
    **EDIT** seek beat me too it. Get a tuner/auto lecky to check it out and find the fault hey. Save you money in the long run
    --- All your base are belong to Phil Bradshaw!!! ---
    <<< blog >>> build thread<<<
    Dave
    Quote Originally Posted by seek View Post
    damn straight.....
    i dont hear of anyone else having blown up 3 adaptronic ecus?
    pluss.....how many "what ecu is the best" threads do we need.....
    and also....a new ecu wont stop wiring faults killing it
    Moderator Frak's Avatar
    Jamie
    I've had Autronic ecu's (SM2's) on my cars for about 18 years! They have always been incredibly reliable, infact I still own and use an SM2 I got back in around 1990!
    The original SM2 I have just required processor changes(easy) and loom updates to bring the ecu up to current specs. I originally used this ecu on a peripherally ported 13B in an RX3(around 1990), later I changed the processor and loom so I could run it on an NA 20V, the processor change was to update to multi coils, launch control etc
    That's one thing that is good with the SM2 box, Autronic keep upgrading features and all you require is a processor change.
    Senior Member klusio's Avatar
    Kieran
    Yeah re-wiring it sounds like a good thing to look at first
    the cheaper reprogrammable ECU's can get decent power figures yes, however the tunabillity (how fine it can be tuned eg. microtech 500rpm) is limited often resulting in poor cold start, jumps up/down in power delivery, poor fuel economy.
    Aurtronic is a bit more expencive than others and cheaper than motec but offer a good solid product.
    I run a microtech LT10-s on my 4agte, does the job but Im looking to move on to better things
    Brendan
    NORTHSIDE YO
    well ive had the ecu sent up to ant (kaizen garage) twice nd had the whole car up there once... and ant couldnt fnd anything wong with it.. ant wired this engne before it went into my car so all ive wired is the main,fuel pump and fan relays and where its dying is on of the pinouts that run the vvti
    im just to the point where if im gonna rewire it im gonna go all out and buy a motec, i dunno why they keep fucking out on me
    my idea of it is the ecu cant handle my everyday driving with the vvti constantly turning on and off and causing the 2 diodes to heat up and eventually burn out, may not be that but its all i can think of
    MY JZX83 (clicky)
    Senior Member ThatsHowWeRoll's Avatar
    Dean
    Ballina
    I had a similar issue man....i blew up two in a row, one of them was a vvti computer form an s14 and it was the vvti circuit that blew in it first but there was a short in the wiring causing it to blow...so im thinking the vvti section of ecu's are first in the ciruit?
    I had dave manning(he is gun with wiring) go through the whole loom and clean it up and dispose of any loose ends its running sweet as now but we never actually found out were the short was becasue the wiring was a mess.
    I asume kaizen garage would do a good wiring job though.
    John 1:12
    Brendan
    NORTHSIDE YO
    yeah im gonna have to send the ecu back to ant and/or pull my loom apart and try find if theres a fault in the wiring somewhere which i highly doubt as ants done a wicked job with the loom ,its very odd for an auxhilary on an ecu switching something as simple as vvti to not be able to handle it but its the only thing i can think of atm, if ant decides to fix or warranty my ecu i think ill be gettin it back and selling it with the loom (no plugs) and buying a motec which ill wire myself and get yager to tune it as he knows his motecs and beams engines
    MY JZX83 (clicky)
  1. Replies: 2
    Last Post: 19th March 2012, 01:24 PM
  2. ADL: 4age loom and ae86 Jap ecu and Aus ecu
    By rke_011 in forum Car Parts For Sale
    Last Post: 24th October 2011, 07:14 PM
  3. 4agze ae101 ecu and bigport ecu.
    By 86TRD in forum Car Parts For Sale
    Last Post: 4th April 2010, 07:07 PM
  4. Replies: 15
    Last Post: 22nd December 2009, 05:48 AM
