So the interior of my soarer has these gross white plastic bits i want to paint a different colour.
Basically what i need to paint is the gearknob surround, centre console, dash surround and door plastics.
What's the best way to paint these, what paint etc? Was thinking just some plastic primer and similar paint? Any pointers would be sweet
hahaha it's going to be hot pink..
yeah plastic prime them so the paint will stick. rub them back with some scotch bright or 800 wet and dry should do the trick - plastic prime - light rub back if neccesary then paint colour of ur choice
I have tried both the Septone and the K&H products . I found that the K&h BUMPER AND TRIM PAINT TO BE THE BEST . With it no under coat required , just a good clean surface( do not use thinners or prep wash , use a white spirirt ( metho or turps ) wipe on with a wet cloth then wipe dry with a clean dry cloth. It also give great cover on repaired areas . I have just finished another rebuild and did bumpers, mirrors and interoir with K&H with good results.
ONLY THE GOOD DIE YOUNG ------ I MUST BE VERY VERY VERY BAD
AE86 4AGE 16V N/A TRACK CAR ( RED )
AE86 ROLLING SHELL --- IN CASE i F-CK UP !!!!!! (PRIMER )
AE86 ADM UNDER CONSTRUCTION ( STREET CAR) 4AGE 16V , (RED )
AE86 Trueno ( RESTORE TO PERIOD GOODNESS ) White
AE86 4AGZE Wreck ( to be rebuilt into Khannacross fun car )
KE 15 x 2 -- SPRINTER ( RESTORE TO PERIOD GOODNESS ) RED
TE72 (T18) X 2 BIT OF PAINT , BIT OF MECHANICAL way we go RED
Soarer 1995 1JZ Factory 5speed (R154 )
Just ask Aaron or did you not see his silvia when it had pretty colours everywhere in the interior, haha
VHT trim paint is fucking awesome, worth every cent.
Get me spade out and dig up some ol shite right here, Revival time.
I just got a replacement dash for Ae71, but its brown and want to paint it black.
So 2 years down the track, does this peel up?
Try vynal die. Won't crack or lift cause its dieing the vynal not just putting later of colour offer the top
I've had good luck with that VHT vinyl die as well. It lasts too.
