Page 18 of 18 FirstFirst ... 8 9 10 11 12 13 14 15 16 17 18
Results 171 to 178 of 178
Thread: 4AGE cams......choices, dyno results and discussions!!!
  1. #171
    Mar 2011
    Ali
    Quote Originally Posted by bunki86 View Post
    Unless ya have big lift or turning ya motor to 9k. I wouldn't waste money on them toda under bucket shims. Then you have to pay some one to set them up. If they dont supply the right shims, then they have to grind valve stems.
    i just built a motor with them and i think he wasted money on that toda setup when the money could have been better spent else where.
    uprated springs for sure. Ya running boost now so boost on the back of the valve is going to counter seat pressure.
    Toda uprated 16V springs are cheap enough, i'll get some happening.
    Does the GZE run a different spring to a GE, or no?
  2. #172
    Mar 2013
    andrew
    perth
    in stock form, i dont know. but aftermarket 4a 16v springs will with both.
  3. #173
    Oct 2016
    luke
    somerset
    wellington
    United Kingdom
    Hi im new to this site iv got a 1984 trueno booter 1.6 4age and ive come across this thread and am in need of advice !
    im fitting a 272 deg cam to my 86 and ive got the following parts
    cam belt
    water pump
    steam seals
    x2 camshafts
    pulleys
    gasket kit
    head bolts
    my cams are going to give me 8.1mm of lift will i need to change my shims ?
    i dont want to start the job and become stuck and not have all the parts i need !
    also can i install them and leave the timming relatively oem so i can get it rolling roaded / tuned ?
    thank you in advance
  4. #174
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    Changing cams requires the clearances be checked and adjusted. You will need to make adjustments. Measure all shims as they are in position. May get lucky and just swap positions. Look on club4ag I think the thread was written by assasin86
    Big up's for the North East Massiv'
    NSATB - New Skids Around The Block
  5. #175
    Apr 2010
    Mitcham
    Hi, i'm looking to fit a 'race' cam with around 300 duration to my AE86 big port. It has forged pistons with 9.5 compression. Head is refurb but stock. I am open to changing to under bucket shims and new springs if required.
    My question is simple: who should I buy these parts off if i am looking for the best deal? Appreciate company names and even online websites. I know this thread has some great information, but it is also very old at the start. I am based in Adelaide.
  6. #176
    Jun 2011
    james
    oxford
    general area
    England
    Quote Originally Posted by s2 sevs View Post
    Non turbo I guess with those cams ? If so then 300° cams could use a whole lot more compression, probably 11-11.5-1
  7. #177
    Marco
    Agree with above comment. Cams if you want it polite on the street, look for 272 or 264 with +7.9mm lift (toda). Can buy online, would not recommend ebay for cams or gears.
    Sent from my GT-S7275Y using Tapatalk
  8. #178
    Apr 2010
    Mitcham
    Quote Originally Posted by Slimer86 View Post
    Thanks, yes NA. Will think about how I can increase the comp.
    Any suggestions on good online stores for cams? I can't see how to buy toda over their website. Cheers
  1. 4AGE Team Toyota Australia dyno runs
    By Frak in forum Technical - Articles
    Last Post: 3rd September 2013, 03:08 PM
  2. Looking for stock dyno results of 4age's(16v)
    By odessy in forum Technical - Questions
    Last Post: 15th June 2010, 08:24 PM
  3. ECU Choices
    By oni in forum Technical - Questions
    Last Post: 18th August 2008, 08:37 PM
Tags for this Thread
