Page 7 of 18 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 ... LastLast
Results 61 to 70 of 178
Thread: 4AGE cams......choices, dyno results and discussions!!!
  1. #61
    Senior Member trueno85's Avatar
    Ayden
    Silverwater
    the dyno results for the modded smallport are really good interesting news! so basically with increased bottomend compression and an aftermarket ecu it will scream.
    do you remember what settings were on the cams? although im sure you would not say what they were if it took you that long to set them perfectly!
    also with the smallport what was the condition of the motor?
    great solid info though!
  2. #62
    Jun 2009
    Ken
    Liverpool
    I've ordered Kelford 193a Camshafts, which are 266 degrees with 8.75mm in lifts. Will be ranning on 4age 16v blue top along with JDM ECU.
    Will post up a graph before and after once its all done.
  3. #63
    Jason
    Southern Suburbs
    Good work with cams. Slightly higher lift than the Jap's use, so may want to get some springs when they come up.
    Jamie, when are we getting those GZE graph's? Everyone says supercharges have better response. Only a graph will tell. I also hear you may have access to a 20v silvertop turbo motor graph, towards 400hp i believe.
  4. #64
    Veteran slydar's Avatar
    Dimitri
    Quote Originally Posted by trueno85 View Post
    not really. small ports are awesome. theyre just hard to find, especially so in good condition as there hasnt been a tonne of low K ones imported into australia un like every other 4age variant.
    78's
  5. #65
    Veteran DAMO46's Avatar
    Jun 2009
    Damian
    well guys iam selling one thats been rebuilt, 80rwkw with all standard internals, no upgrades except airfilter and minor head work
  6. #66
    Moderator Frak's Avatar
    Jamie
    Quote Originally Posted by jaz_ae86 View Post
    Jason, I have the GZE scans here, just gotta scan on to computer(will do a bit later) and post up, problem with the 20V turbo is not a proper graph(as you can imagine )
    Hachiroku since 1994
  7. #67
    Jamie
    Quote Originally Posted by slydar View Post
    If I were to do a 16V I would only use a small port head.
  8. #68
    Jamie
    Sorry, didn't dial in after, once they were optimised I guess it doesn't matter other than for reference, but we ran out of time. If I had them(I guess I can find out) I would post up, no secrets.
    The engine had been rebuilt so was fairly fresh.
  9. #69
    Senior Member Gavatron's Avatar
    Gavin
    Western Suburbs
    You need to get John down to tafe in the KE25 and give it a run to compare it to your AE111.
  10. #70
    Jamie
    Quote Originally Posted by Gavatron View Post
    That would be intteresting as when his and Craig's were run on 98 on the engine dyno, the BT smashed the ST, especially at the top end, which even going on the graphs posted previous is the same.
  1. 4AGE Team Toyota Australia dyno runs
    By Frak in forum Technical - Articles
    Last Post: 3rd September 2013, 03:08 PM
  2. Looking for stock dyno results of 4age's(16v)
    By odessy in forum Technical - Questions
    Last Post: 15th June 2010, 08:24 PM
  3. ECU Choices
    By oni in forum Technical - Questions
    Last Post: 18th August 2008, 08:37 PM
Tags for this Thread
