Page 9 of 18 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 LastLast
Results 81 to 90 of 178
Thread: 4AGE cams......choices, dyno results and discussions!!!
  1. #81
    Senior Member Slimer86's Avatar
    Marco
    North Adelaide Suburbs
    Small ports have a smaller internal area with comparison to the big port head.
    Obvious yeah, I know, but as the area of flow increases, the velocity of the fluid in the area (port in this case) decreases, but as a side note, pressure in the port is increased.
    Small port heads have a higher velocity of fluid flow in comparison to the big port head.
  2. #82
    Moderator Frak's Avatar
    Jamie
    Quote Originally Posted by lucifer d View Post
    If someone can supply a nice clean bigport and small port head, I'll flow bench em.
    Hachiroku since 1994
  3. #83
    Ash
    Ya mums
    i do but in briz
  4. #84
    gay
    n1gger land
    n1gger land
    south korea seoul
  5. #85
    Senior Member trueno85's Avatar
    Ayden
    Silverwater
    how come you would only use the smallport head? i thought the rods are good enough to hold high rpm as long as you change the pins?
    Quote Originally Posted by Frak View Post
    Sorry, didn't dial in after, once they were optimised I guess it doesn't matter other than for reference, but we ran out of time. If I had them(I guess I can find out) I would post up, no secrets.
    The engine had been rebuilt so was fairly fresh.
    sounds good mate, if you do find out what the settings were let me know as i would be very interested to know
  6. #86
    Ash
    Ya mums
    If Bill Sherwood is anything to go by then if using 304 or more cams a big port might be a better option. Obviously this is a pretty crazy engine though.
    180hp - 190hp
    Definitely 304° cams, and you'll have to start paying attention to tuning the inlet manifold length, if you haven't done so already. This is also getting to the limit of what a lightly ported small port head can manage.
    190hp - 200hp
    Getting towards the upper limit of 304° cams, and you'll also need to have the compression up to a good 11:1. 200hp is about the limit for a small port head, no matter what the porting, so from here on the big port is the way to go. Another area that has pretty much reached its limit is the stock valves - Past 200hp you'll be needing the big valve kit. More on that next paragraph.
    The standard exhaust manifold has also reached its limit, so 200hp is about as far as you can go with an engine that still retains a large amount of standard parts. It will need to be revved to around 9,000rpm to get 200hp, though if built properly the engine will still be able to be driven on the road.
    I’m guessing those hp figures are it the flywheel.
  7. #87
    gay
    n1gger land
    n1gger land
    south korea seoul
    well a smallport has the best port velocity and also compression stock compare to a bigport also stock.
    modify them both and still the smallport should have an advantage.
    for a streetable engine i would always use a smallport.
    my mr2 is a bigport and my trueno is a smallport and the 2 engines feel pretty different i think in terms of streetability and other factors.
    toyota wouldnt switch to an inferior design
  8. #88
    Veteran slide86's Avatar
    Huw
    Hills
    If I were to do a 16V I would only use a small port head.
    same opinion for a forced induction engine?
  9. #89
    land yacht
    for forced induction 20v
  10. #90
    Veteran Robo86's Avatar
    Rob
    hmm after this i now want ae111 quads + hks 264s... like the sound of 90 wheel kw
    http://shirtstuckedin.com/
    my corolla
    Bosman Wholesale Tyres
    3274 5374 - Roy
  1. 4AGE Team Toyota Australia dyno runs
    By Frak in forum Technical - Articles
    Last Post: 3rd September 2013, 03:08 PM
  2. Looking for stock dyno results of 4age's(16v)
    By odessy in forum Technical - Questions
    Last Post: 15th June 2010, 08:24 PM
  3. ECU Choices
    By oni in forum Technical - Questions
    Last Post: 18th August 2008, 08:37 PM
Tags for this Thread
