Results 1 to 8 of 8
Thread: Seized cambertops
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    Default Seized cambertops
    Hey guys I just went for an alignment today but when trying to make the drivers side would barely budge, I tried crc and rubber mallet trick no bingo, has anyone had this issue and a simple solution besides replacing?
    Veteran timbo's Avatar
    Tim?
    Wild West
    What, both the moving plate and bolted plate are seized?
    Dave
    Western Suburbs
    got as far as undoing the bolts on them, but when trying to adjust it back and fourth for camber it doesnt move
  • #4
    Tim?
    Wild West
    Belted the shit out of it? What brand are they? You might have to take the tops of the strut and work at them on a bench.
  • #5
    Veteran Jdm-Mcc's Avatar
    Jake
    Wagga Wagga
    Loosen off the bolts and jack up the car under the crossmember so the suspension droops and see what you can do from there, if its still tight undo all the bolts and get a block of wood and a hammer and belt the shit out of the sliding plate until it seperates from the plate that bolts to the strut tower
  • #6
    Hair model Jacobxxx's Avatar
    Jacob
    Bangalow
    Have you jacked the car up?
  • #7
    Tim?
    Wild West
    Quote Originally Posted by Jacobxxx View Post
    Haha I hadn't thought of that...
  • #8
    Dave
    Western Suburbs
    lol, jacked the car up after this thread put the jack under the lca and un did the bolts... seems like the cambertop is fowling against the body but the other one has more movement =S im thinking maybe the its hitting the thread of the bolts holding the strut brace or the camber top in
  • Similar Threads
    1. rt142 cambertops.
      By RRX-007 in forum Technical - Questions
      Last Post: 28th June 2010, 11:22 AM
    2. Ae86 Cambertops
      By Sly* in forum Cars or Parts Wanted
      Last Post: 5th January 2009, 09:32 AM
    3. Engine won't turn over, seems to be seized.
      By PULSE in forum Technical - Questions
      Last Post: 2nd September 2008, 04:43 PM
    4. panhard rod is seized up to the max
      By sprinters_r_mad in forum Technical - Questions
      Last Post: 18th July 2008, 02:10 AM
    5. cambertops spacers
      By .wolfwood in forum Technical - Questions
      Last Post: 7th August 2007, 01:47 AM
