reset tps, and also check the plug on the temp sender at the back of the head, mine wasnt running for shit gave it a jiggle, now mint, also, your not starting at all seems like coil power....converted looms like to do that
you need another ECU man??? got 2 bp amd and 3 JDm ones here.. fuck just read small port , had any luck at all? have you tried waiting till it starts fucking up (leave it running at home drive around block 400 times) and then checking over everything (cas signal, spark, injector pulse, ECU power blah blah)
coil power which will be injector power also
not if your running dizzy
beleive coil power is black with orange trace and injector power is also the same colour, power the pos side of the coil from the battery and it will power coil and injectors
I'm running a JDM loom though Claw. I've also tried another ecu that came from a running car and no deal.
get it rewired, complete engine loom
