Could just get a 90 degree metal bend ad get another hose. Never had anything to do with a 20V though,
Car - KE70 Wagon
motor / part in question - ST20V
problem - Cooling System RWD configuration, Bottom rad hose needs to be some kinda universal flexible radiator hose?
occurs/started when (if applicable)- N/A
personal situation (if applicable)- N/A
Did a search, couldn't really find anything that was the same situation
Where can I get some kinda universal flexible radiator hose?
I went to Supertheif and they don't got jack, just a whole bunch a sh#t that i can't use.
Anyone who has done a 20V RWD conversion with stock 20V water pump and a 16V RWD alt bracket, what
bottom hose did you use and where can I get one?
Yeah, I figure that, but don't want the extra fail point in the join and extra clamps.
I really just want a single hose if I can.
I just prefer the stock hose + 1 joiner to a 90 degree bend. It shouldn't be failing so I don't have a problem with it
Yo got da rwd alt bracket der. put dat one rwd pump on der.
most people use a thermostat housing as a joiner and a hose redirecter.
expensive way of doing it
i fixed your spelling mistake
