You can do that with 10/8 rates...
I will be doing it with 12/10 or 10/8 rates in AA63 [celica, 100-200kg heavier]
I have driven with both Excel G and AGX, and I highly reccomend spending a bit more and getting AGX.
what dampers are you planning to use?
Cheers, I'll defs be going with the AGX's next time around in the track car. They seem to get a good wrap. At current I'm just enjoying how much better than the stock rubbish the excel G are, lol.
Dave- havent given it to much thought yet as i need to get a trailer built before i get coilovers as i have everything for my car to put it back together only thing left to upgrade is the excel g 8kg f, excel g r with bumpstop coilovers thinges and 6 kg spings i bought off u, dont mean that in any sort of way, just want super low (drill off chassis rails and make up new ones for the inside+ full seam weld and tower to tower roll cage so it can handle the spring and damper rates). i know of a 86 build and the dude used like 23kg/mm f-20 r (around that anyways) and he got the whole bilstein coilover set up off a true race car, forget the category of racing it was form but they were lighter that a 86 and he recons it handles quality.
Marv- i dont think 10kg-8 will suffice. i recon 15kg-12, 12kg-10 will though, as i wana run around 10mm ride height from the floor pan maybe go a bit higher if i really need to. as well as i will rasie it, fiddle with the dampers and have a go at lakeside to see if it handles if its shit im not worry, i will just go with the norm on that side of things for my time attack car if thats the case
fair enough
will be good to see it when it comes time
