need more negative offset/good tyre sizing. ie 14" 185/55, or 15" 195/50 with wheels that are 0 offset or 'deeper'
Car - Ae71
motor / part in question - Tie rods
problem - Just installed a set of ground control coilovers using some of AJPS's tie rods and cut and shut steering knuckles and T3's lcas and rcas. My current wheels are 13x6.5 unsure of offset and they are scrubbing is this normal for a set up like this and is the only option getting larger wheels?
Cheers in advance
Thats what i thought. cheers
get some spacers
MOPAR or no car!
i'm assuming they're the ajps slimline balljoints also?
i'd suggest just getting 14's or more. i'm suprised they hit actually.
mabey a small 8mm wheel spacer hit give you alittle clearence?
What size RCA's? Cant run 40mm with 13's
he has 30mm i think
Pics?
they are 35mm rcas... ill get some pics next time im in the shop... illl just stick with some 14s for now cheers
