Found a diff for spares, but this will be it for the F series, just doesn't cut the abuse I throw at it it seems.
Off to see my fabricator tomorrow to get the ball rolling on a G series.
Popped the drivers side axle today, fml, was shortly after a clutch kick but still...
None in stock....so who has F series bits they would be so kind as to sell? Axles, centres, complete etc
I have a feeling the YR22 Rago housing is a unique width compared to the others though I could be wrong.
Lol, sooner rather than later ;p once my tax return clears I could keep the mighty crawf busy for atleast a month or 2
Had a think about diff options today and decided whilst I have the F diff apart it's worth while having the housing checked for straightness...
Thinking back to the last time I aligned the car at work it did have some neg camber and toe in on the RH side...not ideal for a solid axle
May be work hardening the axle at the centre, that in conjunction with the dirty slapping tramp I did have might explain eating axles
Just an option before I drop coin on an upgrade.
recon you might be onto something there with the bent housing dan.
what about a hilux diff with equal length 4 link?
Equal length is overrated for the expense really, but yeah just a dollars thing to go G series atm Will.
Also top shots of the boys in the wet at round 2, Symmons Plains raceway.
Awesome edit by THP, and top track as well!
Also keep an eye out for mah blue shit box at 2min something...
Looked real slippery out there
Awesome work. What gearbox are you using?
Cheers, tis good fun...running a w58 alloy sandwich plate box atm japman, loves it thus far
I want a 1jzgte in my corona :-)
