Results 1 to 4 of 4
Thread: 7AGE Engine Package. Motor + Gearbox + ECU. HAWWWWT STUFF
    Veteran Robo86's Avatar
    Rob
    Exclamation 7AGE Engine Package. Motor + Gearbox + ECU. HAWWWWT STUFF
    Hey guys, my motor setup is up for sale!
    For those who don't know about 7AGE's, its the same mounting/running hardware as a normal 4age. bolt in job. just displacement is now 1.8 and has a gang of torque!
    The motor has been on the dyno just after it was built made a healthy 110whp. its more about the torque these motors produce rather than the power figure. watch!
    PS. can take you for a drive in it, as the car is still driving etc.. MASSIVE WIN, never get that chance.
    -Custom 7AGE Motor (7afe bottom end with big-port 4age head) (not even 2 years old)
    -7AFE Bottom end - Honed, 0.5mm Oversize bores.
    -Standard crank (mid-sized)
    -Kings Main bearings
    -Standard Conrods (Resized + new bolts)
    -ACL Con-rod bearings
    -Hypatech Small-port 4AGE Pistons 0.5mm Oversized. (new)
    -Hastings Piston Rings
    -New standard thickness 4AGE Toyota head gasket
    -Standard Big-port 4AGE Head, with some mild porting.
    -New Head-bolts
    -4AC Flywheel with new bolts
    -Apexi Air Intake
    -TRD style extractors
    -Compression ratio: 11.4:1
    -Standard 4AGE ECU (been run up on dyno, safe as houses)
    -JDM T50 gearbox (good nick! redline oil in it)
    -Extreme Heavy duty clutch in good nick!
    -JDM AE86 Tailshaft
    Notes:
    -Great reliable motor, still has alot of the factory goodies, Coldstart etc.
    -BOLT IN JOB!!! VALUEEEEE
    -Id probably say the motor has done 30,000 since being built! i cant give a definite answer as my speedo doesn't work in the car.
    -Took some heart when we built this, new seals throughout etc. not a throw together!
    -Bottom end was put together by TOXIN off these forums, we went to great detail in the build. you can find it in this thread:
    Pricing: $3,000.00
    Pics:
    http://shirtstuckedin.com/
    my corolla
    Bosman Wholesale Tyres
    3274 5374 - Roy
    E-Famous (Remeber your roots)
    Such a good engine! As you can see it was a VERY anal build, making sure everything was spot on and done correctly!
    Good NA build! or add some rods from Toxin and throw a T28 on it and it will love life.
    Rob
    Just compression tested this bad boy, great results.
    -185/190 across the board!
    my corolla
    3274 5374 - Roy
    Rob
    Price Drop. $2800. this is too cheap!
    -motor
    -box with hd clutch
    -ecu + engine loom
    -JDM tailshaft
    -starter/alternator/aircon
    my corolla
    3274 5374 - Roy
  1. Wanted-4age smallport package motor ecu loom
    By Catch My Drift in forum Cars or Parts Wanted
    Last Post: 11th September 2011, 07:27 PM
  2. 4age bt20v engine+ecu+gearbox package for sale (qld)
    By SIR-86 in forum Car Parts For Sale
    Last Post: 18th June 2011, 12:30 AM
  3. RWD 4AGZE Package: Engine, Loom, Ecu, Gearbox and Tailshaft
    By heartagram AE86 in forum Car Parts For Sale
    Last Post: 9th September 2010, 01:01 AM
  4. Built 16v 4AGE motor and gearbox package
    By Andy San in forum Car Parts For Sale
    Last Post: 21st July 2010, 09:40 AM
  5. sr20det blacktop engine package complete motor/box/loom/ecu
    By d_spec84 in forum Car Parts For Sale
    Last Post: 11th April 2010, 08:27 PM
Tags for this Thread
