Results 1 to 5 of 5
Thread: Detonation/pinging
    Veteran 70rolla's Avatar
    May 2010
    Tyler
    Sutherland Shire
    Default Detonation/pinging
    Hey I have problem a rather bad one my motor is detonating almost constantly the motor is
    A
    16v Jap bigport
    It has pretty high comp
    Running bt pistons a Trd 0.8mm head gasket and a bit milled of the head only a bit
    It's running a stock Jap ecu
    I run 98 octane fuel it was ok for a while but has gotten bad
    I do need to get it on a dyno but what can I do to stop the detonating
    Add octane booster? Retard the timing?
    Senior Member Deeken's Avatar
    Jan 2011
    Deeken
    Port Macquarie
    Probably both man, high comp = increased combustion temps which = need either more fuel/less advance/higher octane.
    Ok
    Seamus
    Milton
    Octane booster is crap. That setup should comfortably run at stock ignition timing (~15 degrees). I wouldn't be suprised if it's running alot more than that.
    If it isn't that, then you may have got a nasty batch of fuel. Never rule this out.
    ^ Clicky clicky!
    May 2010
    Tyler
    Sutherland Shire
    Yer the tank is running low I'm going to swap with a clean tank and fill it with fresh 98 I want to get the distributor checked out and get the timing checked too
    Veteran timbo's Avatar
    Tim?
    Wild West
    Run a bit of kero with the next lot of fuel to clean up anything in your fuel system. Worked wonders for me.
  1. 4AGE Silvertop Lean and Pinging?
    By sloth in forum Technical - Questions
    Last Post: 13th August 2010, 11:21 PM
  2. Possible pinging
    By AE71 Rolla in forum Technical - Questions
    Last Post: 20th October 2007, 12:50 AM
