Results 1 to 3 of 3
Thread: Tas 4agte drift car. resonably competitive car
    Josh
    Default Tas 4agte drift car. resonably competitive car
    located in hobart tasmania. Im selling on behalf of my friend only reason being hes not on the forum and i have been the only one to slide this car.
    Body wise: it has had a very quick respray, body work is rough but good from far far from good haha.
    engine, susy, running gear:
    4agze, custom plenum, custom turbo manifold, kkk turbo, microtech ecu, V mount intercooler radiator setup, oil cooler, w58 gearbox, heavy duty clutch. Custom made front coilover on ae86 struts, Mazda 4 spot calipers and mini rotors with adapter. 35mm lengthened control arms, rack spacers, t3 camber tops, power steering knuckles. G-series diff with rebuilt factory lsd, bluebird disc and twin caliper setup with hydraulic handbrake. whiteline adjustable front and rear sway bars. 15x8 -4 superlites will come on the car
    Theres probably heaps more info i could give you but the best option is to give az a call or fire him a messo to get all the details. I'll get any questions answered if you want to ask here,
    Car makes a 175rwks on 14psi or around abouts that as im not sure on exact figures, dyno sheet can be provided.
    Hes chasing around 7k ono or will put a full cams approved rollcage in the thing and sell for $10k just due to the time and materials to do so.
    Aaron Martin is his name and his number is 0418186758
    cheers josh
ID:	22890   Click image for larger version.
ID:	22891   Click image for larger version.
ID:	22892   Click image for larger version.
ID:	22893   Click image for larger version.
    Brodie
    Very quick car, and well setup. I was struggling to keep up in a 270kw sprinter with RSR's on the back haha. Would be a good buy
    Josh
    think you'll find that was the pilot not the plane you were struggling with haha. as if anyway you were hard on my hammer all day
  1. 4agte ae86 drift/track car part out
    By _wanna-be_ in forum Car Parts For Sale
    Last Post: 7th November 2012, 08:29 PM
  2. Tas Ae86's - Trueno Track/Drift Car Build
    By Tas AE86 in forum AE86 Owners Forums
    Last Post: 24th October 2012, 06:16 PM
  3. 4AGTE 20Valve track car Fast fours feature car :)
    By ke70drift in forum KE70 / AE71 Owners Forums
    Last Post: 27th May 2012, 11:18 AM
  4. Toymods Tas Car Cruise May 16
    By ecko in forum Hobart & TAS Events and Discussion
    Last Post: 17th May 2009, 04:02 PM
  5. white car paint kit [TAS]
    By Jonny Rochester in forum Car Parts For Sale
    Last Post: 26th March 2009, 01:06 PM
