it would help slightly. but not really needed.
just fill it up like this
whats the story with putting the centre in the oven on high for 15 mins to heat it in prep for welding? ive heard several different people doing this.........
sexy ^
my stick welded f series in my corona has lasted near on 10000km total and two 1200 return km drives to brisbane and a fair amount of abuse and axel tramp in between, i made sure i filled it to the brim and flushed it out with diesel, then changed the oil like 4 times in the first 1000km even then it still had some slag on the magnetic plug........
I remove the typically remove the ring gear and pre-heat the assembly with a torch to until the spider gears are 700+ degrees (start to 'blue'). Then use a rolled up piece of 'wax' type paper stuffed into the splined spider gears to prevent slag sticking to the splines.
Andrew
Judging by the photo
a: there wasnt enough weld/penetration
b: alot of splatter.
Cleanlyness and preperation is key to a good weld.
Preheating the diff centre will definatly help, pre heating your work makes a huge differnence.
But honestly, i would not put a diff centre in my oven, i cook with that shit man.
All i would honetsly do, basicly almost max your wleder out ( single phase i pressume) with the right wire feed, you should be able to hear when it is welding nicely. and just lay bead after bead.
If you cant weld, weld alot
I probably wouldnt arc it, for the sheer fact of how long it would take a inexperience welder to fill gaps with it.
that also being said removale of slag in hard to reach spots is a ####
PM me if you want I'll do it with the mig at work. (Heidelberg area)
It's a CIG 220.
LOL..
You ALL do it wrong...
The only part you need to weld is the 2 side gears to the casing.. I usually do 2 or 3 runs as it takes a while to fill it out enough to satisfy me. But I have done HEAPS of diffs this way, and NONE on them have EVER broken.. and most of them were in 400+ hp drift and drag cars.. there is absolutly NO NEED to go filling the center with weld and bolts and bits of plate and random peices of shit..
It a lot easier on nissan diff as you can disasemble the center into 2 halves and weld each gear almost the entire way around.
^^ Has some truth. Welding the side gears to the housing is one of the most important things (which hasn't been done in the photo further up). Welding the spider gears together and spider gears to the housing also helps, but to a lesser degree. Good penetration is a must, and pre-heating with an oxy torch improved my results.
But to answer the original question, yes, just reweld it properly and you should be set.
On the 2 peice centers, I don't even refit the other gears as they're no longer needed... They're just added weight
