Results 1 to 10 of 19
Thread: XT130 Struts and brakes with AE86 PS knuckles - Smaller diameter ball joints / better LCA?
    Veteran stahlz_ae86's Avatar
    Paul
    Default XT130 Struts and brakes with AE86 PS knuckles - Smaller diameter ball joints / better LCA?
    Hey folks,
    In my AE71 I've been running XT130 struts (which I converted to coilovers) for around 6 months now and I'm wanting to correct the steering geometry.
    My setup consists of...
    XT130 Struts shortened 2 inches to suit ST185 inserts
    XT130 brakes
    AJPS 40mm RCA's
    XT130 Steering knuckles (super long)
    XT130 Lower control arms
    My brother and I worked on the car today, with intentions of installing AE86 PS knuckles but encountered the problem of the LCA end hitting the rear face of the brake rotor. After looking at it for a bit it was clear the cause was the location of the ball joint hole in relation to the two strut bolts. I've had a bit of a search and found others who encountered the same issue and fixed it by smashing the end of LCA with a hammer. That idea sounds a bit average to me and I've been thinking of modifying the XT130 steering knuckles.
    Rather than doing that, my question is... What other Toyota's or even other makes of car might have a similar style LCA with a smaller diameter balljoint and therefore smaller radius end? KE30/55 pops to mind but not being in Auto trade I don't have access to books / parts on shelf etc.. Can anyone check the BJ diameter of a KE30/55 in a book at work? Not only that I will need to know if the taper will fit the AE86 PS knuckle too.
    Whatever I do to solve the issue I'll update it here, but I sure as hell will not be "fixing" the issue with a hammer. I'm running +3 caster and don't like the stress it pulls on the LCA bushes as it is, so I'm considering another LCA with a smaller radius at the end on which I can modify the inner ends by cutting off exixting bush hole and plating/tapping to use rose joints/rod ends.
    Another couple of things I thought of to fix the issue were NCRCA's which upon further thought seems like a dumb idea, or a longer RCA to push the LCA low enough that it clears the rotor. Either way those 2 ideas seem to suck. If I can't fix the problem with LCA's I might have to resort to modding the XT knuckles.
    Are there knuckles from another Toyota which are similar length to AE86 PS but have the balljoint hole on the outer direction of the strut bolt holes?
    Veteran AJPS's Avatar
    Lonsdale
    ra40 knuckles have a slight ncrca effect...
    they are about 10mm higher than most and sit further out
    Paul
    Do you know what the distance between the balljoint and tie rod holes is by any chance?
    Hair model Jacobxxx's Avatar
    Jacob
    Sunshine Coast
    Are ra40 similar to ra60/mx73 struts where the bolt holes are further apart than ae86/xt130?
    Lonsdale
    sorry I dont, it was a while ago that I had some
    But I would suggest cutting them down as they were 'corona' long
    they also had very little ackerman
    Lonsdale
    dont quote me but im pretty sure they were xt/ae pattern
    Mt Macedon
    RA40, AE86 and XT130 all share bolt spacing on their steering arms. In other words all those steering arms will bolt to all of those struts.
    Paul
    Anyone know an answer to the LCA radius / ball joint size question?
    Veteran timbo's Avatar
    Tim?
    Wild West
    Does it foul with the wheels straight or when you turn them?
    Jacob
    Sunshine Coast
    Did not know that. Interesting. What are ra40 brake sizes like compared to ae86/xt130?
  1. WTB XT130 LCA's & AE86 Power Steering Knuckles (W.A)
    By HILTZ in forum Cars or Parts Wanted
    Last Post: 16th November 2012, 12:51 PM
  2. Replies: 13
    Last Post: 23rd January 2012, 11:04 PM
  3. XT130 LCA's brand new nolothane bushes ball joints
    By jakel in forum Car Parts For Sale
    Last Post: 20th February 2011, 10:51 PM
  4. Sigma GE LCA's, as new bushes, ball joints
    By Ramcam in forum Car Parts For Sale
    Last Post: 19th August 2009, 10:20 PM
  5. SuperPro LCA bushes & Ball joints (SA)
    By Dave in forum Car Parts For Sale
    Last Post: 6th August 2009, 02:26 PM
