Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: air box for ke70 and the old 4age (loads of pics)
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    Default air box for ke70 and the old 4age (loads of pics)
    OK so here i am going to show you how to install a Holden vr commie air box into your ke70 cut and shut small port / cut and shut bigport i don't know if the jdm bigport manifold will work due to the throttle body facing down but i am unsure
    1:find yourself a fucked up Holden vn-vs get ur air box out of it
    2:cut inside of the box until it fits like in the pics demonstrated
    3:make up a couple of brackets like illustrated in the pics
    4:use the existing coupler to mark the hole needed to run intake to the wright spot
    5:u will need to move ur charcoal canister down onto the cross member yes you can keep ur charcoal canister
    6:make yourself a block of plate and bolt all the shiz in
    7:u will need to get rid of ur washer bottle and overflow bottle i moved my overflow bottle in front of the rad support if u have money u might be able to use an ae86 jdm washer bottle but ill let u blokes sort that out
    the end result is fairly stock looking also has a good power curve compared to not running a filter at all or a pod filter alternatively u can give me a pm so i can pass on a message to Adam at kurnell customs who hepled me do this airbox
ID:	350   Click image for larger version.
ID:	351   Click image for larger version.
ID:	352   Click image for larger version.
ID:	353   Click image for larger version.
ID:	355   Click image for larger version.
ID:	356   Click image for larger version.
ID:	357   Click image for larger version.
    the dyno pull to 300rwkw
    性交を愛する
    Good work.
    looks good bro. well done
    West
    Looks great. I bet it breathes well. Perhaps try to seal the cutout with rubber and draw your air via a feed from the front?
    Mathew
    Sutho Shire
    m8 considering it but i have diff issues atm and it breaths very well and as i may have said power curve is so clean i love my 4age
    cheers boys for the comments really appreciate it
    Mathew
    Sutho Shire
    ok i have installed the k&n panel filter and the car goes a little harder but i will need to open up my exhaust for more flow and cams and an ecu but the k&N filter really helped pickup and overall power is really good i would recommend this mod to any1 with an e7 and a 4age also cleaned up the old shitty rubbers got all new black 1ns looks so stock
    Senior Member OMG866's Avatar
    Nick
    Miranda
    seen it in person ppl, really good cheap way to stay out of any trouble from the pigs
    Mathew
    Sutho Shire
    cheers nick when you get a rolla ill help you put 1 in
    Paul
    Maidstone
    i think i am going to try this in my ae86
    2 in the pink 1 in the stink
    Mathew
    Sutho Shire
    i still run this now days on the track and all, pod filters are just dumb and over rated
  1. Phuoc's EVIL86 article (loads of pics 56k beware)
    By evil86 in forum AE86 Owners Forums
    Last Post: 25th November 2012, 10:34 PM
  2. (vic) air filter/ air box for ae86 w 4age needed asap
    By dove grey 64 in forum Cars or Parts Wanted
    Last Post: 11th October 2011, 07:29 PM
  3. 4age factory air box
    By enigma in forum Cars or Parts Wanted
    Last Post: 1st July 2009, 06:22 PM
  4. JDM 4AGE AIR FILTER BOX AND PIPE TO
    By orangechargd86 in forum Cars or Parts Wanted
    Last Post: 10th February 2007, 08:41 AM
  5. 20v RWD conversion PARTS. air box pics up!
    By federal in forum Technical - Questions
    Last Post: 6th December 2006, 06:49 PM
