And extractors, not sure on degree and lift for the Cams with stock valves..if you're going to run an aftermarket ecu look into silvertop or blacktop throttle bodies as well but Cams ecu extractors and throtlle bodies is about the limit for stock bolt on Mods
265 is about the limit on the stock comp...will need something like an apexi safc
