nothing wrong with that, you say you don't have pressure in your top hose?
Hey guy im having overheating problems with my 20v. at idle it will reach 98 degress. what ive notice is that my bottom pipe is not hot and other pipe may not have any pressure. can someone confirm if my water routing is right. sorry to be annoying
Top radiator hose - engine - Rear bypass - heater core - heater tap - back of water pump - thermo housing - bottom hose
Pick up Sydney
Pics can be sent by phone
Emails ignored
Texts ignored
Private numbers ignored
Wankers abused
hmm your radiator is all good?
are any lines kinked?
you have sq rwd kit right?
Just another Muppet
Top is hot bottom is not so hot
Pick up Sydney
Emails ignored
Texts ignored
Wankers abused
well that would be normal to some extent. Although it does at this stage point the finger at your pump. What fan are you using?
Brand new aftermarket pump and twin 10" thermos
Pick up Sydney
Emails ignored
Texts ignored
Wankers abused
post some pictures of your setup then
After work as im in the spray booth at the moment.
thanks for posting interest Sam
Pick up Sydney
Emails ignored
Texts ignored
Wankers abused
I know your microtech display shows at 98, but check the standard temp gauge see if it's also reading high,
Check your thermostate.. Maybe take it out and see if your get a cooler temperature reading for testing purpose..
dose
Might just be a sluggish thermostat. Ive felt in the past with a remote thermostat housing on a 20v, you get the head too hot before the thing opens and then evens the heat out, the bypass doesn't seem to cut it, and I feel its faulty to have the thermostat away from the head in this application. Before you all bite my head off, yes the remote thermostat housing is a toyota part from a fwd 4ac, but its not the correct (or even approximate) location for a thermostat on a 20v. Ideally you want the thermostat to be the sentry that only lets water pass into the radiator from the engine if its hot enough. Even more ideal would be making the cooling system flow in the standard pattern with standard in and out points (like only the TTT kit does).
Other causes of overheating might be blown head gasket or cracked head, or a blocked radiator. Does it lose any water? Does the water stay green. They arent known for running hot and not known for BHG issues either.
