been pretty busy on the s12 over the last couple of days. i really wanna get it to a roadworthy state asap. so while all the front sus was stripped out i stripped back all the old crusty sound deadener out with a rotary wire brush, cleans them and sprayed them with killrust and new deadener over the top. looks like new now.
my new coily's rocked up the other day to so i test fitted them in the nice clean wheel arch
next thing was to strip the front end. its had a repair in the past, was a pretty good job they used alot of sealent, so im stripping all that back and the surface rust under it and treating it all with killrust and repainting it all. while all the parts are off they'll all be thoroughly cleaned and or painted. theres also sooooo much overspray on everything and its such a bastard to get off. so all the plastic pieces i have painted with brake fluid to strip the paint back without damaging the plastic.
its all coming up pretty good. im gonna order some paint next week and i'll hope to have a fair bit of the parts prepped ready for colour
its all in black killrust primer atm. will hit it with some paint soon enough.
also dropped the steering rack ready for modding. it was covered in sooo much shit. took ages to get it all off. now i have to rethread the s13 tie rods, adding 10-20mm extra thread and cut the same of the end so the s13 tie rods and ends will work with the s12 rack. then add some lock spacers and thats it for steering. other than maybe modding the LCA's and knuckles
i was but they dont reply to emails. i'll keep trying coz their fuckin crazy lookin wheels.
in other news
my twin tips arrived 2day. thought i'd be a poser and take some snaps. should look sweet once i weld it all up and position it. im really not a fan of the rolled ends so im gonna chop em off
2.5inch in 3 inch out
u can see the difference in size compared to stock :LOL:
finished work early so decided to do some panel work on the old slapper. i could see that there had been quite a bit of bog used in the repairing of the filler panel below the lights so i carved all that off, sanded it all back and got to work tapping out the 2 large dents in the panel.
tools used:
- 3 dif types of hammers
- a screw driver i filed down to tap out square edges
- small peices of timber custom axed with a tomahawk :LOL:
- tomahawk
gotta love backyard jobs lol
anyway got both dings out really easy and its only going to need the lightest skim of bog if any to finish it.
well thins kind of opened a can of worms because it lead me to the left panel, which i noticed had some bog on it to. so i stripped that back to reveal a really bad kink it the nose piece that houses the front parker lense. so the panel had to come off for repair.
knocked all that out and got it really really straight. this piece wont need any bog its that straight now. while i was fuckin round with that paint started to chip off the wheel arch so out came the wire wheel and i started to strip that back, u know what i found? YEAP...... BOG fuckin dodgy kents! ah well stripped it all off and started to tap the panel back to shape but it started to get too dark so i laid some killrust on it and went inside.
gonna need alot more work to get it nice and straight again
pretty happy with my panel beating skills these days. i used to just be a bog man myself lol. but if im gonna build another car it may as well be up to standard of my 180sx so its gonna be as spot-on as possible
so car currently stands like this......
dun dun dun
and just to give u's an idea of how far out that nose piece was here is a before and after with a line guide
it had been bent right in and kinked it completely
so i showed it who's boss
so i bitched out and just bought a set of hoshino's that were for sale locally. i finally got a reply about the 4 spoke wheels and was a little disappointed. the 4spoke 3 piece wheels are no longer in production and i can only get them in a one piece and at $300+ per wheel plus shipping and tyres it was pushing a little to high for a "cheap" build lol so the hoshino's had been for sale for a while and i finally decided to just buy them even just for the time being i guess i could always widen them.
specs are 14x7.5-1 front and 14x8-7
i originally wanted 15s but looking at a few examples of s12's running hoshino's in 14inch my mind was soon changed
picking the wheels up on wednesday night cant wait to start reco'ing them
in australia impossible to find but in the usa they were a factory option. an mkii front bar in australia is hard enough to find. but got both
so i picked up the hoshino's . they're in pretty pox condition but should scrub up alright. im going to reco them as much as possible, new bolts, new paint, carve all the gutter marks off them and polish them up. pretty happy with how they sit, will have to run a 5-8mm spacer on the front to clear the sr brakes but all in all they look tough.
so last night i was finally able to go and pick up a pair of s14 caster rod brackets for the s12. 2day after work i modified them to fit the 12 and bolted them in.
so three out of four holes line up so just measure, drill and ya laughin :LOL:
once that was done, in went the s13 LCA
then the knuckle, hub and the coilover goes in
cant do much more till my adj. caster rods arrive and i can find a die with a m12 x 1.25 thread pitch so i can cut some more thread on the tie rods. also have to test fit an s14 swaybar. so i thought i'd start on the next project.....
a few months ago i bought a really old s13 strut bar. now the reason i bought this particular one was because it had really long mounts on the strut brackets and a short cross bar. i did this becase the s12 towers are closer together than an s13. so instead of doing what alot of people do and cut the mounts off, mod them and weld them back on in a different position all i gotta do is measure, drill, cut off excess, shape, paint, profit
these should explain it a little better. where the dots are i drill a hole then chop it shorter, shape a nice end and bolt it all up. i also thought that i had run into a problem of the bar fouling on the throttle cable BUT the mounts are offset about 10-15mm so i just spun it around and got enough clearence yay
oh and hey look some wheels
front have some pretty serious poke due to the s13 lca's lol and i still have to run a 5-8mm spacer so that the wheels will clear the brakes. so im just gonna machine the calipers a little to give me better clearance and less poke. the rears sit well but i might need to run a small spacer to match the fronts
fun times!
