Results 1 to 10 of 13
Thread: Niteparts Bellhousing
    Senior Member DR86FT's Avatar
    Kaan
    Emerald
    Default Niteparts Bellhousing
    Need help with positioning slave cylinder on niteparts bellhousing? what did you do?
    Kaan
    Emerald
    Any problem with this coz I'm gonna run it
    As long as it throws the clutch fork far enough and it doesn't move it'll be fine
  • #4
    Kaan
    Emerald
    Quote Originally Posted by Matt View Post
    Thanks will test once I get my flywheel bolts and put the motor in
  • #5
    Mar 2011
    Ali
    Dig.....
    What clutch fork and pivot did you use?
  • #6
    Kaan
    Emerald
    Quote Originally Posted by Futo_gt86 View Post
    Dig.....
    The w5x one
    Sent from my SM-G935F using Tapatalk
  • #7
    Mar 2011
    Ali
    I'm using ST20V 212mm flywheel and I don't know which clutch fork/ball combination to use to get it right.
    I also purchased Niteparts CNC bearing carrier extension, as supplier suggested, to be used with low profile FWD 20V Pressure Pate.
    The 20V starter motor doesn't fit, not even close.
    What clutch setup, was it GZE, 20V, Smallport, Bigport?
    What starter motor did you use?
    What slave is that one you used?
    Did that slave set up work for long on that funny angle?
  • #8
    Mar 2013
    andrew
    perth
    do you know what w5* one ? as there is many different forks. and it looks like you have the right short one, as all the others a longer.
  • #9
    Mar 2011
    Ali
    I found this info on Toymods
    http://www.toymods.org.au/forums/thr...ing-w55-fork-s
    w55 style forks can be found on the following...
    notched = M, K (km36 G52), K A & T (only from 22spline T50), (shortest type) approx 113mm pivot to clutch slave
    straight = T (3tgte), G, C (ce71), (middle type) approx 118mm pivot to slave
    bent = R, S, C (cr30 G52), (longest type) approx 125mm pivot to slave
    I'm new to ToyoDIY, can someone please correct me if i'm wrong.
    I posted up in Toymods but weeks have gone past since then.
    Thanks.
  • #10
    Senior Member spoon's Avatar
    Oatlands
    I know with my niteparts bellhousing i had to use all t50 stuff. i originally bought a new W5# fork but was too long and t50 stuff all bolted up fine...
  • Page 1 of 2 1 2 LastLast
    1. FOR SALE.. W5x > 4a bellhousing (Niteparts NZ)
      By slideways in forum Car Parts For Sale
      Last Post: 18th August 2009, 04:32 PM
    2. wtb wx to 4a bellhousing (niteparts)
      By DR86FT in forum Cars or Parts Wanted
      Last Post: 1st August 2009, 06:50 PM
    3. Niteparts bellhousing and W58 or similar
      By asher in forum Cars or Parts Wanted
      Last Post: 18th July 2007, 06:18 PM
    4. niteparts 4a to w5x bellhousing
      By slo-055 in forum Car Parts For Sale
      Last Post: 30th May 2007, 11:56 PM
