It would appear that i need to get an injector resistance pack thingy which...
The injectors being used are pink
Hey,
Problem
Car won't run
Happening Since
4age was installed into a ke70
Issue
The ecu appears to be giving out weak injector pulse, it is pulsing, but not enough to fire the injectors. I've seen this in the past and it has been weak earths.. If you manually earth the injectors temporarily the car will start.
Has anyone else seen this before and is it likely to be a faulty ecu?
Thanks
What 4age are you running and what ecu?
Bigport for both questions.
