Results 1 to 5 of 5
Thread: Spark plugs for 4age
    Senior Member DearmanKE's Avatar
    Alex
    Northfield
    Default Spark plugs for 4age
    G'day folks,
    Just wondering what spark plugs people would recommend using in a bigport 4age.
    The car is used for drift so it gets hammered if that makes a difference.
    Formerly known as grape_moosha
    Member AB-Ke70's Avatar
    May 2011
    Billy
    Thomastown
    firstly, if the car is gonna be given a hard time dont even look at iridium or platinum. they'll foul out quicker and cost you 10x more money for no gain.
    you should only run standard copper plugs especially for drifting. dont trust my memory too much but i think they are NGK part number: BCPR6ES-11
    ill double check for you tonight.
    main reason why i use NGK is because i know they work, and i always have them in stock at my work.
    Alex
    Northfield
    Yeah fair enough, I have just done the head and rings after I blew the gasket and found it had 3 standard and 1 iridium/platinum, the cylinder that had that plug had some damage in the comb chamber that seamed like detonation, do hopefully if I put a new standard set in I won't have a problem
    Alex
    Northfield
    And yeah if u could double check the part number that'd be sick, cheers
    Senior Member Deeken's Avatar
    Jan 2011
    Deeken
    Port Macquarie
    Yeah, I am running bcpr6es-11 in mine too, remember to check gaps before you put em in too, they vary a little out of the packet.
  1. spark plugs
    By wntdae86 in forum Technical - Questions
    Last Post: 14th June 2010, 11:34 AM
  2. spark plugs
    By sprintdaddy in forum Technical - Questions
    Last Post: 4th May 2008, 02:43 PM
  3. what spark plugs do you use??
    By jeenyus in forum General Topics (No Technical Questions)
    Last Post: 20th April 2006, 12:12 PM
  4. 4AGE Spark Plugs
    By Simon-AE86 in forum Technical - Questions
    Last Post: 24th February 2006, 11:19 PM
