Lube up the pin and the bolt that the calliper moves along, under the rubber boots. You would only need to replace the pistons if they had damaged the bore by becoming off centre, which in that case you would also need to sleeve them. I got a genuine front rebuild kit of ebay well over a year ago for $20 from Japan so keep that in mind. I should actually rebuild mine...
