Page 1 of 55 1 2 3 4 5 6 7 8 9 10 11 51 ... LastLast
Results 1 to 10 of 544
Thread: 2AZ powered 86
    West
    The world has turned.
    Im going to get it on the road with the silvertop, but ultimately this car will be powered by a 2azfe 2.4 litre all alloy vvti inline 4.
    bahahahahahahahahahah
    West
    .,.vv
Name:	my 2az 1.JPG
ID:	5265   Click image for larger version.
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    wow interesting...................
    still got your parts sitting in a box in my garage dude..........
    BENT MECHANIX - Garage 20:
  • #4
    Veteran driftke70's Avatar
    Ryan
    Buderim
    nice, should be a screamer, let me know if you need a hand.
    wheelfriends.wordpress.com
  • #5
    Veteran trikzlane's Avatar
    Mereki
    Badassville
    looks like a build to keep my eye on
    ~KEEP DRIFTING FUN~
  • #6
    Davey & Riki-lee
    South Australia
    Seaford SA
    woooo camry motor lol
    what do you have to mod for this one bud?
    Our introduction - Click here
  • #7
    West
    Almost everything.
    I dont even know what gearbox will fit it or go close, but Im keen just to work out out all the details.
  • #8
    Ryan
    Buderim
    think there is a pickup in the usa, a certain model of tacoma that has a bell that fits rwd layout, goes to a either a w or r box. clutch wise would depend on the bolt spacing and what its like originally, obviously the flywheel has its radius on the wrong side for the starter, still work, but noisy, use standard ecu/adaptronic, engine mounts are no biggy, looks like it has clearance to fit pretty well.
  • #9
    West
    Yeah, Im looking into reverse mounted starters (which is the correct way around for this engine anyhow, and will suit the flywheel. I might make a hybrid bellhousing rather than machine motor after motor to accept a starter like a 4age. It will be low mounted if I do it from the bellhousing side so cleaner looking bay and lower centre of gravity, also more between the wheels.
    Im fitting my AE111 ITBs to it, and will invest some good money in a really well made manifold for it. the inlet ports are like a more spaced out bigport flat sided oval, so the manifold will have to adapt the shape much like a bigport from the circular itb butterfly to the oval port. The throttles will need to be centred over the ports also, and can point upwards a few degrees to aim better at the port and clear the clutch master and brakes.
    Still dunnio exactly what gearbox fits it. I just hope I can use the flywheel and clutch I have in the end.
    The motor is obviously here now, and Ive assessed its condition. Im comfortable to say its almost 100 percent new. It has been run. It has very light carbon deposits in the exhaust manifold, the spark plugs are nice and golden, the ports are clean, the ignition coils have no corrosion, the clutch isnt worn, its just a perfect motor. It spins over super smooth, you can still feel light friction in the water pump from the seals before really being spun. There is no water in the motor and no sign of it. There is a crappy pricing gun sticker with a date on it on the sump. November 2007. Im guessing it was a demo car motor that got rear ended or dropped off the truck pre delivery, I cant imagine any other reason to remove a motor this fresh. I imagine if the motor had really gotten hot, it would have melted the sticker off the sump in a snap.
  • #10
    West
    Some photos.
    Check out how bad the factory collector is!
Name:	sexy time in the googlesack.jpg
ID:	5396   Click image for larger version.
Name:	back of motor.jpg
ID:	5397   Click image for larger version.
Name:	date sticker.jpg
ID:	5398   Click image for larger version.
Name:	front of motor.jpg
ID:	5399   Click image for larger version.
Name:	rear of head profile.jpg
ID:	5401   Click image for larger version.
Name:	crimp collector.jpg
  • Page 1 of 55 1 2 3 4 5 6 7 8 9 10 11 51 ... LastLast
    1. The 4age powered Toyota 86
      Last Post: 18th December 2012, 11:36 AM
    2. 2AZ COP's - JJR recliner - rear shocks
      By biggo in forum Car Parts For Sale
      Last Post: 11th August 2012, 11:15 AM
    3. WTB: coilpacks + plugs off 1NZ, 2AZ or 1ZZ
      By Sam-Q in forum Cars or Parts Wanted
      Last Post: 15th February 2009, 08:09 PM
    4. 13b/13bT powered 86's?
      By jarryd in forum Technical - Questions
      Last Post: 30th November 2007, 01:01 AM
    5. Calling all CA18DET powered 86's
      By lowau in forum General Topics (No Technical Questions)
      Last Post: 21st August 2006, 11:06 AM
