Results 1 to 9 of 9
Thread: 4AGTE exhaust size
    Bryan
    Waterford
    Tramore
    Ireland
    Default 4AGTE exhaust size
    Car - Daihatsu Charmant
    motor / part in question - 4AGTE exhaust
    problem - What diameter
    occurs/started when (if applicable)- not yet
    personal situation (if applicable)- I like cake
    What size piping for a 4AGZ with T25 from SR20? Going to run on AE101 ecu for now and was thinking of 3" down to where the cat
    would be normally but would I keep it 3" all the way back or would there be an advantage in stepping down the pipe size to say 2 1/2" to the silencer box?
    Also as a road car I don't want it to be silly loud.
    Thanks.
    Alex
    Wagga Wagga
    I run a full 3" system in my car with a centre and rear exhaust. Turbo is a KKR330 which is about the same size as a t25 I believe. Also, mine is a daily and I would say the exhaust note is pretty quiet, I'd almost say legal actually!
    Alex's 4AGTE KE70
    Or so was thought...
    3" if it'd fit... 2.5" won't choke it too bad, but defo try to get 3"
  • #4
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    2.5 will do fine unless your making 200kw
    AE86 THE BEST
  • #5
    Veteran AJPS's Avatar
    Lonsdale
    +1 on 2.5
  • #6
    Senior Member Vaughn's Avatar
    Vaughn
    Sunshine Coast
    There was a thread about exhaust sizes that was for 20v though, but i would expect around the same size. supposed 3" is best
    Just another Muppet
  • #7
    Dave
    Nsw
    Livo
    im running 3" to my "cat" and 2.5 from there back.... but not by choice. would much peffer 3" all the way.
  • #8
    Mar 2011
    Dave
    SE suburbs
    should make the dump and front pipe out of 3", then you can drop it to 2.5" from there to the back. this is fine on one ta22 4agte 20v i know of that makes over 200rwkw on 19psi.
  • #9
    Bryan
    Waterford
    Tramore
    Ireland
    I got a CX Racing T25/8 to V band adaptor to suit 3" piping which I am going to run down to the cat area.
    I was going to do a step down decat pipe and use an AE86 cat back I have here, but then I was thinking I'd just get
    a full system made up.
    Sounds like 2.5" will work fine so thanks.
  • Similar Threads
    1. Exhaust... Size, Pics?
      By KurtHS in forum Technical - Questions
      Last Post: 16th August 2011, 11:10 PM
    2. exhaust size
      By bart in forum Technical - Questions
      Last Post: 6th August 2008, 10:47 AM
    3. Turbo exhaust size
      By the_sleepa in forum Technical - Questions
      Last Post: 9th September 2005, 03:49 PM
