Results 1 to 1 of 1
Thread: cant drift this..... easily
    Senior Member macca1590's Avatar
    Central Qld
    Default cant drift this..... easily
    owned it for a while now and a boring rainy day lead to me making this thread
    anywho is a 92 80 series landcruiser, got it mates rates from a guy at work
    factory turbo
    430,000kms, just run in
    supposed 3" lift, bought it like that
    33" bfg muddies
    new transfer case when i bought it
    a/c done just before i got it too
    boost gauge
    exhaust with all mufflers cut out
    since i have owned it
    built and installed 2nd battery tray, all wired up with solenoid(links batterys when engine has oil pressure and during crank to give both a work out)
    welded up cracks and made plate to go over chassis where steering box mounts (apparlenly most lifted 80's and live axle 100's do it)
    re wired headlights with extra relays and new semi sealed inserts
    installed cheep and nasty snorkel
    extended diff and gearbox breathers
    extra fuel filter
    exhaust gas temp gauge
    boost tee (now 14psi)
    played with max fuel screw on pump
    changed all wheel bearings
    changed big end bearings (http://www.lcool.org/technical/80_se..._bearings.html)
    plans
    steel bullbar
    maybe a 3" exhaust
    maybe a intercooler
    go camping and shit
    and pull shitty nissans out
  1. Online parts database, find part numbers easily!
    By jet111 in forum Technical - Articles
    Last Post: 31st March 2013, 10:23 PM
  2. WA KE70 Drift/track. Ready to drift or minus motor/box
    By mayday in forum Cars for Sale (Toyota Only)
    Last Post: 19th April 2012, 04:11 PM
  3. can EASILY swap a st 20v for a bt 20v
    By dave2221 in forum Technical - Questions
    Last Post: 20th July 2009, 09:34 PM
