Results 1 to 7 of 7
Thread: Polishing wheels help
    Member SR_andy's Avatar
    Andrew
    Heritage park
    Default Polishing wheels help
    Ok so I just picked up a full set of hero z1
    14 x 6.5. They are in desperate need of a polish.
    Basically I was going to start with some 2000 grit
    Sand paper then polish with autosol. Just wondered
    If there was a clear coat that needs to be put back on
    If I sand them back??
    Any help would be great
    Thanks
    Andy
    Moderator Sam-Q's Avatar
    Endeavour Hills
    Any I suggest a proffesional polisher, compared the amount of labour you would put into it to get an inferior result they are a bargain
    Veteran johl's Avatar
    Johl
    You can run it without clear but you will constantly have to polish them. I agree with Sam. Usually costs no more than $60 per wheel
    Ridgehaven
    I don't recommend clear coat. any small chips that will develop, will start to look ratty real quick.
    easier to just hit em with Autosol every few months than re-polish and re-apply clear coat every few months..
    Endeavour Hills
    I agree, get them professionaly done once then lightly maintain with autosol. I think I only paid $15 a wheel for the twin step lip to be done.
    Andrew
    Heritage park
    Sweet locks like I'll just have to polish them up every
    Couple of months thanks people
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    Just yet another wheel resto queston.
    I have a pair of WORK Ewing Fins, which are a bit rough and I want to clean them up.
    Now, even though they are an alloy wheel, they have a chrome coating/plating which is all flaking off and is pitting.... Now, I tried a wire brush on a drill, and it would get the flaky bits off, but alot of the 'chrome/plating stuff' is really hard to penetrate/come off...
    So, my question is, it there some sort of chemical product I can use to remove the chrome plating without damaging the alloy underneath?
    Would it damage to sand blast?
    Once I get it off, polishing is not a problem, but cant polish them at the moment because of the 2 differant surfaces...
    thanks
  1. Polishing your wheels!
    By gumbie in forum Technical - Articles
    Last Post: 27th September 2010, 07:55 PM
  2. machining and polishing rims?
    By Mr Awsome in forum Adelaide & SA Events and Discussion
    Last Post: 17th September 2010, 07:41 PM
  3. polishing wheels
    By benzo in forum Adelaide & SA Events and Discussion
    Last Post: 25th March 2010, 08:05 PM
  4. Polishing Wheels
    By trikzlane in forum General Topics (No Technical Questions)
    Last Post: 12th August 2009, 10:34 PM
  5. POLISHING TAILIGHTS AND BLINKERS
    By wide s13 in forum General Topics (No Technical Questions)
    Last Post: 6th March 2008, 10:59 PM
