I'll take the flywheel
Part-out has begun...
Running AE71 CSX manual with 4A-C and original ADM box, borgy diff etc, pedders springs, stock wheels. White with blue interior, Pioneer MP3 headunit. $2500ono available for inspection in a couple weeks once I bring the stock motor home and get it going again.
4AGE Small port / red top, T3 adj. cam gears, RWD converted inlet, dizzy & leads, RWD water pump/plumbing, RWD alt bracket, alt, coil, igniter, loom to suit AE71, factory computer, T3 Alloy RWD alt, water pump and crank pulleys, $1500 - Sold pending payment Thursday 29th
Stock AE71 radiator with Thermo fan, $150
TODA lightweight flywheel, Sold - Posted
TRD Clutch Plate, $50 (has been removed and the disk has meat and comes with too)
Cast AE86 exhaust manifold with 2 into 1 stanless pipe, Sold - Picked up
2 ¼ Exhaust, stragiht through one muffler at rear to suit above manifold, Sold - Picked up
Jap T50 5 speed with near new slave, Sold - Picked up
T18 Series 2 diff housing, with new Kaaz 2-way LSD Centre, noisy 4.3 CW&P, $1000
AJPS 4.5kg/mm 245mm free height rear springs, $150
KYB 8-way adjustable Camaro rear shocks, near new, Sold - Picked up
KYB Excel G front shocks from ST185 Celica, XT130 Corona front struts shortened to suit Celica insert, HSD Coil-over kit with 6kg/mm front springs, XT130 single piston front brakes, Lucas Pads, Racing Logic Camber tops, sold as a package, Modded XT130 steering knuckles (AE86 PS length), Sold
Brand new RA60/MA61 slotted vented rotors, brand new lucas pads, New longer M12 bolts & washers, and MX62 Cressida calipers (was intending to install on above coilovers) $300
XT130 Corona lower control arms, bushes and balljoints replaced not long ago, Sold - Posted
25 row oil cooler, thermostatic sandwich plate, -10 hose and fittings (takes Z418 Filter), $300
Speco 2” oil temp, oil pressure and water temp gauge set with senders, $150. Now selling with oil cooler as a package for $400 for both as I remembered the oil temp and idiot light senders are in the sandwich plate
under car surge tank with high flow pump & lift pump, Sold - Posted
Restored 14X7 +2 Volk Fins with Toyo R888 semi's, $1000
DX Taillights, wired and ready to plug straight into Aussie E7 sedan, Sold - Picked up
Chrome front bumper with dodgey irons, comes with indicators and endcaps, $300 On hold for Daniel IOU Photo's
Chrome rear bumper (no irons for this), comes with new aftermarket endcaps, $200 On hold for Daniel IOU Photo's
Clear cam gear cover, $80 Awaiting contact for pick-up, available again.
AE71 gearbox crossmember, $50
Race seat on fixed E7 bracket, suit slim/tall driver, $200
Photo's of removed parts coming soon.
Located northern suburbs Melb. Post in here or PM to express interest in a part/s.
Last edited by stahlz_ae86; 25th March 2012 at 12:22 PM. Reason: Update on Sold parts
1st dibs on clear cam cover if part out happens
Rust is a way of life
pm sent...
Is that flywheel for 20v or 16
16V 200mm, if the buyer of the engine package doesn't add it to their list of parts they want from the car John has first dibs on it.
All PM's replied.
Cheers,
Paul.
Hey Paul,
Are you willing to do discounts for multiple items?
Also is the under-car surge tank one of the group buy ones? Or just generic? Willing to split it from the fuel pumps?
Cheers, Will.
SuperFunHappySliders
SR's are ghey.
I am also interested in the flywheel!
Cash waiting if you want to post!
Hi Paul,
I'd be keen on the front and rear chrome bars.
Will send you a pm now!
Dan
PM me with exactly what you want, depends if there's somebody else who has already expressed interest in the same part or not. The under car surge tank is this type...
