up
My other thread was a bit jumbled up, so yeah:
J160 6-Speed conversion - to suit 4AGE/7AGE motors = $1000
Includes gearbox, custom bellhousing, crossmember, and a HD clutch to suit. Also speedo drive that will directly bolt into AE86 cable.
*Pressure plate might be defective, or slave needs longer pushrod. Gearbox makes some bearing noise (could be normal?), but has been perfect for the 6 months it's been in the car - i am sensitive to noise though haha. Lowered engine mounts/spaced crossmember or tunnel massaging might be required to fit this gearbox in your application.
*Also have a spare, unmodified J160 box = $500
You can contact me here, by PM, or on 0423 766 972. If i don't answer your call, i will get back to you
does the t series tail shaft bolt to this?
ROYAL GARAGE NEWCASTLE
Do you still have the modified gearbox for sale.
