Results 1 to 10 of 43
Thread: Adrian's RA65 Daily
    Aug 2010
    Adrian
    South
    Default Adrian's RA65 Daily
    Heres the new girl,
    1985 RA65 liftback
    22re
    W55
    IRS
    Mods:
    Flower knob, homemade shift boot, new shifter bushes
    MA61 wheels, RE001 fronts
    HSD weld on coilover sleeve with 8kg springs
    Koni yellow adjustable inserts
    XT130 LCA's rebushed and new balljoints, lock stops removed
    KE70 king springs and gt gas shocks in rear (both temporary)
    Thanks for looking
    How I got it
    Next day
    Senior Member macca1590's Avatar
    Central Qld
    yeah weld on sleeve would be the go, easy adjustable ect ect, you can get adjustable spring seats for the rear, or just cut spring to height....
    edit: check out for some pics and stuff of the adjustable rear spring seats
    Aug 2010
    Adrian
    South
    Think ill just get some ajps springs for the rear and adjust the front to suit. Just got to work out what length and rate for the rears, i read in your thread that yours still squated with stiff springs. Im thinking either F 8kg/mm and R 6kg/mm or F10kg/mm and R 8kg/mm or 8kg/mm F & R
    Central Qld
    yeah they are cut falcons thoe, a higher rate would be a whole lot better i would hope haha, im waiting on a reply from ajps for some 6kg/mm myself for the rear so hopefully they go better
    E-Famous (Remeber your roots)
    How low are you wanting to go and how much money are you wanting to spend?? Drifting? Or just grip/daily?
    Aug 2010
    Adrian
    South
    Not quiet sure how low, but it doesnt have to be stupid low and im more after the stiffness. Did a quick guesstamation of the drop i want and id say about R 80-100mm and F 40-50mm.
    After all 3 daily/ grip/ drift
    Edit: Cost, cheap as possible without dodgeyness like cutting springs
    Aug 2010
    Adrian
    South
    Put some ke70 kingsprings in the rear that i had laying around, its about as soft as the stock springs. The koni's i had didnt end up fitting the rear either because they were to short so just got some monroe gt gas one in at the moment. But now the stock springs are out i can work out what i want.
    Aug 2010
    Adrian
    South
    Made a new shift boot the other day and my shifter rebuild kit came today so I put it all in
    Veteran joeschmo_57's Avatar
    Joe
    NT
    Nightcliff
    ra65's are cool!
    Interior reminds me of a late 70's/todays Elizabeth lounge room
    quit hatin get bakin!
    Aug 2010
    Adrian
    South
    Yeah and the interior in this one is pretty clean too
    And they have heaps of cool little things too, like the a cover to get to the washer reservoir for the rear window, the cover is actually a funnel for filling it!! And just under the ignition there is rubber padding on the steering column plastics, so your keys dont scratch the plastics!
  1. Adrian's 4AGE KE70
    By Seventy in forum KE70 / AE71 Owners Forums
    Last Post: 2nd July 2014, 03:53 PM
  2. Jarrad's RA65
    By Jarrad86 in forum Other Toyotas
    Last Post: 12th December 2010, 11:17 AM
  3. Jarrad's RA65
    Last Post: 16th October 2009, 12:09 AM
  4. ra65 strut diameter
    By 4AGE - 86 in forum Technical - Questions
    Last Post: 26th April 2008, 09:19 PM
