Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 30 of 43
Thread: Adrian's RA65 Daily
  1. #21
    Junior Member wolff's Avatar
    Mar 2012
    Aaron
    are you sure about that? I thought RA65 were all w58, yeah my flares are completely different to ma61.
  2. #22
    Sep 2010
    William
    yeah my ra65 hatchback was W55, and the notch back ra65 i just got has a w58.
  3. #23
    Aug 2010
    Adrian
    South
    Okay, so did the coilover conversion on the front struts last week and added xt130 LCA's. Had abit of a headfuck fitting the stock strut tops to the koni shocks, but turning up a spacer fixed that. Very happy with the handling, just got to sort out the rear springs, but yeah it just sticks to road like a magnet and also have heaps more lock now with the lockstops cut off.
    Picture time
    Before
    After
  4. #24
    Aug 2010
    Adrian
    South
    Also need to fix the toe problem these get when you lower the rear, is it as easy as an rear wheel allignment or do i have to modify something?
  5. #25
    Sep 2010
    William
    looks nice, did you trim the strut tube down? or were the shocks standard length?
    otomoto sleeve kit?
    what front tyre size are you running?
    there is stock adjustment for toe but not camber.
  6. #26
    Aug 2010
    Adrian
    South
    Nah didnt cut the strut tubes down because they were standard length shock, but it would be nicer if i had short strokes.
    By otomoto i mean HSD weld on sleeve kit.
    Front tires are 185/60
    And yeah i know that theres adjustment for the toe, but i was just wondering if the adjustment pin will have enough adjustment as it has a fair bit of toe out.
  7. #27
    Sep 2010
    William
    Only one way to find out i suppose, get an alignment, this will also tell u how much camber you got with the xt130 LCAs!
  8. #28
    Aug 2010
    Adrian
    South
    So just been driving this really.....
    Blew the head gasket around august last year, fixed that up and she has been running sweet.
    Tried some 205mm 6kg AJPS springs in the rear today, were too low and still abit soft (crappy dampers probably dont help). So just put the other springs back in for now, so would probably need something around 220-240mm and 8kg or 6kg and better shocks.
    Anyway heres a pic
  9. #29
    Aug 2010
    Adrian
    South
    Also some 25-30mm bolt on spacers would be good for the rear, but doesnt worry me too much and dont really like wheel spacers...
  10. #30
    Senior Member Wagon86's Avatar
    Feb 2012
    Sa
    seaford rise
    When the head was off did u check the timing chain guides wernt broken??.
  1. Adrian's 4AGE KE70
    By Seventy in forum KE70 / AE71 Owners Forums
    Last Post: 2nd July 2014, 03:53 PM
  2. Jarrad's RA65
    By Jarrad86 in forum Other Toyotas
    Last Post: 12th December 2010, 11:17 AM
  3. Jarrad's RA65
    Last Post: 16th October 2009, 12:09 AM
  4. ra65 strut diameter
    By 4AGE - 86 in forum Technical - Questions
    Last Post: 26th April 2008, 09:19 PM
