Results 1 to 8 of 8
Thread: [BNE] W5x G/box Crossmember + JDM EFI fuel tank (both suit AE86)
    Senior Member PuGZoR's Avatar
    Andy
    Thornlands
    Default [BNE] W5x G/box Crossmember + JDM EFI fuel tank (both suit AE86)
    Hi all,
    Alright, I need the following:
    1) W5x gearbox crossmember to fit on an AE86. It's going on an AE101 4AGZE block with a Niteparts bellhousing. I'd imagine that any crossmember made for a 4A to W5x should be fine, but thought I'd say that anyway.
    2) JDM EFI fuel tank with in-tank pump. I don't care if the pump doesn't work (as long as I know), but I just want everything because I'm sick of cutting stuff. Yes, this needs to have come off an AE86.
    3) Bit of a long shot, but after a shifter for a W5x too. I unsuccessfully tried to modify mine... Need one that has a friendly throw for an AE86, too. I've got a W58 (supposedly from a non-turbo JZA80), if that counts for anything.
    Thanks.
    Andy
    Thornlands
    Shameless bumpage... might have a shifter sorted but not 100%.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Are you sure its a JZA80 shifter you are after? They are totally different to any of the other ones as they are an external shifter. Would come up just in front of where the handbrake lever bolts down if you had one.
    Andy
    Thornlands
    Yeah, probably not hey. It's a W58, but definitely doesn't have the external shifter with linkages.
    Veteran 44GTE's Avatar
    Craig
    Upper Caboolture
    Hi Andy
    I have the JDM EFI pump setups available if you get stuck. Will go straight into the ADM tanks . Only difference is the ADM arn't baffled and will get surge on hard RH corners when below 1/4 tank
    Let us know
    Otherwise have a JDM tank but it will need a clean out and reseal/ treatment as has rust inside.
    Contact No: 0408998795
    EMAIL: justjdmimports@bigpond.com
    LINK TO MY WEBSITE FOR MORE PARTS & PICS http://www.justjdmimports.com
    Link to My ride Thread http://www.ae86drivingclub.com.au/fo...y-Latest-Daily
    Moderator Sam-Q's Avatar
    Endeavour Hills
    apparently the auto mx83 gearbox crossmember bolts up
    Lawrence
    Wollongong
    Interesting, I'll have to give that one a go when I'm up to that stage myself.
    Senior Member DR86FT's Avatar
    Kaan
    Emerald
    I have a shifter position that is the furthest forward position for a w5x
  1. HOW TO: ADM Fuel tank to suit efi
    By z_brutalis in forum Technical - Articles
    Last Post: 11th November 2013, 10:33 AM
  2. WTB, AE86 JDM style Fuel tank ( as in EFI Tank )
    By Lexsmaz in forum Cars or Parts Wanted
    Last Post: 1st August 2010, 10:20 AM
  3. WTB JDM EFI AE86 fuel tank.
    By Faceplant456 in forum Cars or Parts Wanted
    Last Post: 4th February 2010, 09:33 PM
  4. WTB: JDM AE86 EFI fuel tank with pump
    By Mr Awsome in forum Cars or Parts Wanted
    Last Post: 12th August 2009, 09:39 PM
  5. JDM EFI fuel tank
    By bart in forum Cars or Parts Wanted
    Last Post: 16th June 2008, 10:41 AM
