Results 1 to 10 of 19
Thread: Just JDM Imports Track Car Build
    Veteran 44GTE's Avatar
    Craig
    Upper Caboolture
    Default Just JDM Imports Track Car Build
    Hi All
    Been flat out lately and can't see things changing for quite a while yet.
    Have had a White Hatch that i imported a couple of containers ago and had earmarked to turn into my fun/track car.
    Came in already with a 7 point cage, 2 Recaro fixed back seats , deap dished steering wheel, adjustable castor rods, etc etc
    Not much has happen so far other than swapping over the rear diff ( 4.7 TRD 2 way LSD disc rear end), Rear TRD coil over setup, adjustable lateral bar and removing the engine/ gearbox for the impending 3SG SXE-10 Beams engine running 20V black top quads, HKS exstractors, ORC clutch , 6 speed gearbox and of coarse an Adaptronic ECU setup.
    The front setup is still to be done, it will be running Willwood Calipers setup off my 4AGTE car , coil overs with new HTS 112 adjustable shock inserts and cusco camber tops.
    The bit that i am going to post up tonight is the wheels in which i will be running. Weds Albino custom made 15 x 8.5 -10 ( thanks Terry) with Bridgestone Potenza Re002 205/50/15 tyres .
    Terry will also be doing so minor adjustments to the rear arches in the coming weeks so will show the updates / improvements as you can image the wheels don't fit under the stretched standard arches.
    Anyway enough shit for now.
    Couple pics of the wheels for all to drool over
    Cheers craig
    Contact No: 0408998795
    EMAIL: justjdmimports@bigpond.com
    LINK TO MY WEBSITE FOR MORE PARTS & PICS http://www.justjdmimports.com
    Link to My ride Thread http://www.ae86drivingclub.com.au/fo...y-Latest-Daily
    Jake
    Northgate
    Sounds good! What are you building it to do or will it be an all rounder? I am sure you have plenty of goody's to make a few good cars
    Also got the caliper brackets Thanks!
    Craig
    Upper Caboolture
    Hi
    I am building it for laps , not drift at all. I just want to get out and have a bit of fun and who knows where i will end up with it in the future.
    Senior Member t-nol's Avatar
    May 2010
    Trent
    Sounds great, can't wait to see the progress on fitting the 6-speed.
    Have you looked into any other ecu's for comparison, or Adaptronic just easier. Saw a tuned Beams with a Vipec (spelling?) last night, retaining the dual vvti.
    Craig
    Upper Caboolture
    Hi
    No the adaptronic is just easier and i know it works. I have an adaptronic on my 4AGTE setup in my other car and works great. Also have Anthony ( Kaizen Garage) up here to sort it out when required.
    Craig
    Upper Caboolture
    Some average pics of the car before with smaller Albino wheels on it.
    Will get some more of the car shortly weather permitting to get it out.
    Veteran stahlz_ae86's Avatar
    Paul
    Nice, should be good as you work your way through it. I love the Weds. So fresh!
    Senior Member Andostack's Avatar
    Jan 2011
    Nice, Craig let me know how those tyres go, and those rims look really good.
    Craig
    Upper Caboolture
    HI All
    Slow process, but finally have the Engine and 6 Speed gearbox installed.
    New ORC Clutch and Flywheel kit
    New TRD Engine Mounts
    5Zigen Extractors
    Engine and Gearbox brackets supplied by Anthony Kaizen Garage
ID:	26300 Click image for larger version.
ID:	26301 Click image for larger version.
ID:	26302 Click image for larger version.
    More pics later
    May 2010
    Trent
    Are those engine mounts just a flat plate in the middle? No gussets for support, cause they don't look like very good quality at all.
  1. Tas Ae86's - Trueno Track/Drift Car Build
    By Tas AE86 in forum AE86 Owners Forums
    Last Post: 24th October 2012, 06:16 PM
  2. Dave's KE70 budget track car build
    By lildavo in forum KE70 / AE71 Owners Forums
    Last Post: 16th April 2012, 12:43 AM
  3. KE70 Drift/Track Car Build.
    By luke641 in forum KE70 / AE71 Owners Forums
    Last Post: 19th March 2012, 06:50 PM
  4. SRE70 Track Car Build up
    By chrizer in forum KE70 / AE71 Owners Forums
    Last Post: 2nd June 2008, 01:50 PM
  5. track car build. sr hachi roku killer
    By Jamie in forum AE86 Owners Forums
    Last Post: 26th March 2008, 08:19 PM
