Results 1 to 10 of 12
Thread: T-series axle measurements + photos - Zenki & Kouki explained
    Default T-series axle measurements + photos - Zenki & Kouki explained
    someone had a picture of zenki axle measurement and kouki ones next to eachother with some sort of measurements, can you post that up again cant find it in search section.
    Elite rthy's Avatar
    Leo
    Tulla
    Zenki T series Axle (as on a celica, same size tho)
    Kouki T series Axle (ae86)
    more info on here
    thanks, these pictures will help many people in future, should be stickied somewhere.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    I agree, I'll move it to tech articles section because this gets asked all the time.
    Edited title also - so that its even more clear
    Veteran blair's Avatar
    Blair
    SEQ
    Can we get some more measurements in this thread? i'll put a question thread up in a sec
    Dec 2009
    Andrew
    California
    Nothern
    USA
    8mm length difference between LSD & Non-LSD axles. Non-LSD are 8mm longer.
    So if you've got an OEM lsd, but non-lsd axles you cut 8mm off the ends (splines are plenty long enough) and bevel/taper the end so it will insert easily.
    I found this out a little while back when I had the opportunity with both available to me.
    Andrew
    Last edited by assassin10000; 26th July 2010 at 02:51 PM. Reason: Added measuerments.
    Blair
    SEQ
    I'm mainly after the length of the Spline'd section.
    Mark
    t18 t series: zenki right??
    Sep 2009
    Daniel
    Wellington Pt
    so wat you guys are sayin is if i welded up my zenki diff i can put kouki axles in if i take 8mm off them?
    Blair
    SEQ
    Can you see the pictures above?
    They differ in O.D by over a mm, so the answer is no they arent interchangable at all
  1. Wtb: Zenki t series 2 way lsd (small axle type)
    By TOY3TG in forum Cars or Parts Wanted
    Last Post: 20th July 2011, 05:10 PM
  2. Wtb: kouki axle for t series disc brake
    By munki in forum Cars or Parts Wanted
    Last Post: 18th November 2010, 01:56 PM
  3. kouki & zenki axle Q
    By ae86 in forum Technical - Questions
    Last Post: 28th March 2010, 03:45 PM
  4. crown & pinion, axle for kouki diff.
    By evil86 in forum Cars or Parts Wanted
    Last Post: 28th November 2009, 04:38 PM
  5. Zenki T series Axle
    By pogi in forum Melbourne & Vic Events and Discussion
    Last Post: 4th June 2009, 05:40 PM
